Author Topic: NEEDED: 5 speed selector lever  (Read 4576 times)
December 11, 2010, 10:14:04 pm
erice1984
  • 263
« on: December 11, 2010, 10:14:04 pm »
Need a part.  Here is the P/N  171711177c
Marked with green.
Here is actual picture of the part.  It is the one on the top left.
« Last Edit: December 11, 2010, 10:23:22 pm by erice1984 »
1980 Rabbit 1.9TD
Reply #1December 12, 2010, 04:43:29 am
ktzdsl
  • 73
Re: NEEDED: 5 speed selector lever
« Reply #1 on: December 12, 2010, 04:43:29 am »
I think I have one. I can check by 8:00am CST and let you know for sure. Where are you located?
DFW area Texas
1982 1.6L NA diesel pickup
Reply #2December 12, 2010, 06:53:05 am
ktzdsl
  • 73
« Reply #2 on: December 12, 2010, 06:53:05 am »
Sorry, none left in our stash.
DFW area Texas
Reply #3December 12, 2010, 08:34:44 am
Quantum TD
  • 1195
« Reply #3 on: December 12, 2010, 08:34:44 am »
If you're converting to 5-speed from 4-speed, you'll also need the shifter base/box. They're different too. If you have worn bits, it will be a pain to adjust the linkage in order to hit reverse and 5th.
Reply #4December 12, 2010, 09:11:00 am
« Reply #4 on: December 12, 2010, 09:11:00 am »
you just need the pieces from under the hood.. i used my stock 4 speed shifter rod, and everything else was out of a 5 speed.
Reply #5December 12, 2010, 10:23:05 am
ilikevwdiesel
  • 1202
« Reply #5 on: December 12, 2010, 10:23:05 am »
sent a couple pms
My Bio
Reply #6December 12, 2010, 06:33:16 pm
« Reply #6 on: December 12, 2010, 06:33:16 pm »
Sorry. It is only supposed to get up to 9F tomorrow and I won't be going after the GTI for parts until it is warm. Or I think I could do it and not freeze. I would have gotten it for you though, I just ran out of time :(
Reply #7December 14, 2010, 07:37:37 pm
erice1984
  • 263
« Reply #7 on: December 14, 2010, 07:37:37 pm »
its alright.  Lucas.  I figured you were busy.
I just needed that lever part, I got the shifter base, and linkage and bushings on the way.
So I should be ready to throw the 5spd in it.
What I do need still is an AAZ.  but I need to get more money first.  or if any canadian has a good one that will let go for around 6-700 bucks that does NOT blow oil out the exhaust I could drive to pick it up given a decent day.
1980 Rabbit 1.9TD
