Author Topic: curious, part on driveaxle  (Read 2075 times)
December 05, 2010, 09:39:28 pm
gribur
  • 84
« on: December 05, 2010, 09:39:28 pm »
i was looking at the driveaxle on the passenger side i think it was and there is a part that goes around it, it has some orangish greasy stuff on it or it is made of it i am not sure, and there isnt one on the other axle. any ideas? it is about an inch wide and fits around the axle. i can try to explain better if need be, i am just not sure how to lol.
Reply #1December 05, 2010, 10:08:35 pm
RadoTD
  • 513
    Stage WTF
Re: curious, part on driveaxle
« Reply #1 on: December 05, 2010, 10:08:35 pm »
Picture might help, even if it's taken with a phone
Is it at the transmission end or wheel end? On the axle itself or on the joints?
Try rubbing it with a rag, maybe it's a sticker or something? Possibly a sleeve. The two axles aren't necessarily the same brand, so they don't need to be perfectly symmetrical
enough boost is when you have 3 dimple marks in the hood from the valve cover nuts..  ;D
Reply #2December 05, 2010, 10:13:31 pm
« Reply #2 on: December 05, 2010, 10:13:31 pm »
You are likely referring to the harmonic dampener, if it's a circular disk a inch or so thick and a few inches in diameter.
OEM passenger-side drive shafts have 'em to dampen out vibrations on the longer of the two drive shafts... you rarely seem them on aftermarket replacements like EMPI.
Reply #3December 06, 2010, 02:11:22 pm
clbanman
  • 705
    Cambridge, Ontario
« Reply #3 on: December 06, 2010, 02:11:22 pm »
I cut mine off because it came loose, slid over and rubbed through my brake hose.  Found out as I was stopping for a red light.
Calvin
91 VW Golf 1.6NA 5spd
