Author Topic: question about aaz pump  (Read 4536 times)
November 22, 2010, 12:35:21 pm
vako
  • 187
« on: November 22, 2010, 12:35:21 pm »
my friend has connected fuel lines from fuel filter by mistake on the contrary.   fuel return line to the filter and fuel delivery line to the return line of the car....
we were cranking the car for about 45-secs-1 minute this way before i found out this mistake.   after that i connected everything properly and the car started up after the first kick start attempt.
i have no cold start lever connected and after starting up the car was refusing to idle without foot on accelerator pedal :D  as cooling system isn't finished yet i shut the engine off after 10-15 seconds of idling.
and my question... i'm quite worried, would something happen to the pump because of our mistake?
Reply #1November 22, 2010, 12:48:36 pm
vako
  • 187
Re: question about aaz pump
« Reply #1 on: November 22, 2010, 12:48:36 pm »
pump was primed before every attempt of starting up (with a little pump on filter body)
Reply #2November 22, 2010, 01:39:38 pm
Mark(The Miser)UK
  • 1557
« Reply #2 on: November 22, 2010, 01:39:38 pm »
Most unlikely to have done any damage.
Have you been working on the car for the CSD to be disconnected, or has it never been connected?
Mark-The-Miser-UK
Reply #3November 22, 2010, 06:02:15 pm
vako
  • 187
« Reply #3 on: November 22, 2010, 06:02:15 pm »
edited
, sorry i read "most likely to have done any damage" for the first time i looked at your post  ;D
i'm really revealed now.
as there is a one way valve in  the filter i thought that excessive pressure, if there is any, in drain back line (wich was connected to the filter, instead of the delivery line) could harm something. but there was no fuel getting in the pump (delivery line was connected to the drainback line of the car)... so i hope that i haven't damaged my engine :(  and rough idle was only because of the air in high pressure lines.
« Last Edit: November 23, 2010, 01:01:00 am by vako »
Reply #4November 23, 2010, 01:03:30 am
vako
  • 187
« Reply #4 on: November 23, 2010, 01:03:30 am »
i'll install radiator and try to start my engine again for the weekend.  because i have not got appropriate starter (it will be delivered in two weeks from ebay) and the only way to get my car stared is to kick start it with my friend's mercedes  ;D
Reply #5November 23, 2010, 04:38:05 am
Henchman
  • 183
« Reply #5 on: November 23, 2010, 04:38:05 am »
Just be REALLY sure of your timing!  This is a harsh way to start an engine.  At least with a starter, you have a chance of catching a few unusual ticks if the timing is a bit off.  If you bump start and that timing is out enough, or it jumps a few notches because something wasn't tightened, it'll be short lived!
Ian
Reply #6November 23, 2010, 05:28:08 am
vako
  • 187
« Reply #6 on: November 23, 2010, 05:28:08 am »
Ian
engine came out of a running car, so i think timing  is ok for now... and what do you think about my pump, could something happen to it?  ???
Reply #7November 23, 2010, 05:59:49 am
vako
  • 187
« Reply #7 on: November 23, 2010, 05:59:49 am »
p.s. i have swapped aaz to suzuki vitara  ;D
Reply #8November 23, 2010, 06:08:56 am
Mark(The Miser)UK
  • 1557
« Reply #8 on: November 23, 2010, 06:08:56 am »
Ian
The pump was pulling a vacuum.
This is what it does all the time, but in your case it failed to get the diesel to flow.
Unless you artificially 'drove' the pump for hours, or a long time until the pump body drained of diesel and the vanes dried out and scoured the seating, the lubricated vanes would just leak back the diesel. Apart from feeling a little foolish, I am sure that you have done nothing harmful...
Not so foolish, so as to not recognise your fundamental mistake, so go and have a beer and relax... ;D
Mark-The-Miser-UK
Reply #9November 23, 2010, 10:34:24 am
« Reply #9 on: November 23, 2010, 10:34:24 am »
a symptom of failing AAZ crank nose is crappy idling..
Reply #10November 23, 2010, 12:01:01 pm
vako
  • 187
« Reply #10 on: November 23, 2010, 12:01:01 pm »
thank you very much for your support ;D hope that really nothing bad has happened  ;D
yes i know about crank nose failing problem, i even had a topic about my crank spocket    http://www.vwdiesel.net/forum/index.php?topic=26361.0    but it is not so bad that could fail so soon. and i think that it must be some other issue.  hope it was not my fault LOL
Reply #11November 24, 2010, 12:51:26 pm
« Reply #11 on: November 24, 2010, 12:51:26 pm »
yea, i remember you were talking about doing it, and decided against the TDI crank sprocket upgrade..
i just hope it doesnt turn around to bite you in the @$$...
Reply #12November 24, 2010, 01:49:13 pm
vako
  • 187
« Reply #12 on: November 24, 2010, 01:49:13 pm »
yes i know that sooner or later i will have to modify crank spocket, but i don't think that several seconds of running (without even a pulley attached to the crank) could make things worse :D
