Author Topic: Flexible turbo oil feed line  (Read 2233 times)
November 18, 2010, 01:47:06 pm
gnavs
  • 340
« on: November 18, 2010, 01:47:06 pm »
Any problems using a high grade flexible teflon hose for the turbo oil feed line?  It would be a hell of a lot easier than solid tubing.  Any experience?  Any custom feed line pics are also appreciated :)
Reply #1November 18, 2010, 02:22:07 pm
Re: Flexible turbo oil feed line
« Reply #1 on: November 18, 2010, 02:22:07 pm »
most other people use flexible lines
Reply #2November 18, 2010, 02:42:18 pm
GEE-BEE
  • 1604
« Reply #2 on: November 18, 2010, 02:42:18 pm »
use teflon, an-stuff
37 degree flared is good
maybe a 90 off the filter housing to another 90
When doing any angle to angle the hoses will be ordered like this
13020204-xxxx-xxx
13 teflon ( titeflex) 1500 psi working
02=90
02=90
04=size -4
xxxx hose in inches and eight's of a inch
xxx=rotatation angle
One angles will be clocked at 000 rotation, the other end will be the rotation in degree's
You may purchase a adjustable angle fitting or just add a elbow on both mounting surfaces and you can use  straight fitting's on the hoses assy
I had a aircraft hose shop for years..
teflon hose can be purchased with a clear shrink or firesleeve for protection
let me know if I can help ?
GB
« Last Edit: November 19, 2010, 08:11:57 am by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3November 18, 2010, 03:23:40 pm
« Reply #3 on: November 18, 2010, 03:23:40 pm »
That is what I did. Fittings are about 12.00 each and the hose is kinda pricey. I sold one for around 90.00 ready to bolt onto the car to a guy last month. IIRC JIC 6 hose and fittings. Turbo and filter flange are M12-1.5 to 6 JIC  works like a champ.
Reply #4November 19, 2010, 06:15:16 am
tombarace14
  • 6
« Reply #4 on: November 19, 2010, 06:15:16 am »
I use braided high pressure line from the oil filter to the turbo.  With AN adapters to pipe thread, works great for me.
