Author Topic: My own pop testing thread.  (Read 4853 times)
Reply #15November 13, 2010, 02:31:47 pm
Mark(The Miser)UK
  • 1557
Re: My own pop testing thread.
« Reply #15 on: November 13, 2010, 02:31:47 pm »
Are you vigorously pumping fuel through the injectors each time you swap one onto the tester?  You won't get any accurate results until the air is purged.
Yeah I do, especially after messing around half the night and findng one that pees lots, frustration you know.........
Last night I got the leaky injectors to sorta stop leaking, I think they're still wet around the joint so I'm gonna get new little return lines before pulling the injectors again.
When you replace the tubing, cut them as long as will fit under the fuel lines, so that you can snip a little off on next R & R.
Mark-The-Miser-UK
Reply #16November 13, 2010, 02:48:18 pm
« Reply #16 on: November 13, 2010, 02:48:18 pm »
Yup I did, I used snowmachine primer hose, it was a nice snug fit.
