Author Topic: Head torque sequence when using studs and MLS gasket?  (Read 2241 times)
November 03, 2010, 05:55:41 am
vwjunkie53
  • 98
    • The Volvo diesel forum
« on: November 03, 2010, 05:55:41 am »
Hello everyone,
I just torqued my head on last night with the MLS gasket and ARP studs.  I followed the ARP directions, but was wondering what others have done with the MLS gasket.  Do you guys normally do a retorque after the engine gets warm, to just go around and check all the nuts.  Is the 90lbs that the directions said enough?  Seems like I remember reading someone on here ended up having to tighten them down more to get things to seal.
Thanks,
Jason
1984 Volvo 760 GLE,  "built" D24T w/ARP studs, MLS head gasket, ported/polished head, 3 angle valve job, NA cam, 56mm T3/T4, NA manifold, FMIC w/ 3" alum piping, 3" turbo back, detailed in CAT yellow. T-5 manual swapped w/ Clutchnet 6-puck.  Best of 16.07@86mph with orig. worn out engine.
Reply #1November 03, 2010, 06:37:20 pm
Re: Head torque sequence when using studs and MLS gasket?
« Reply #1 on: November 03, 2010, 06:37:20 pm »
http://www.vwdiesel.net/forum/index.php?topic=21182.15
mid way down the page zukgod's procedure is there. I did a similar one in my build.
Reply #2November 04, 2010, 12:04:50 pm
Syncroincity
  • 727
« Reply #2 on: November 04, 2010, 12:04:50 pm »
I torqued mine in 20lb increments up to 100, but have not run it yet.
Any consensus on re-torque after initial run with the MLS + ARP combo? Necessary or not?
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
Reply #3November 04, 2010, 06:22:44 pm
« Reply #3 on: November 04, 2010, 06:22:44 pm »
I haven't yet. 2,000miles
Reply #4November 04, 2010, 06:26:30 pm
vwjunkie53
  • 98
« Reply #4 on: November 04, 2010, 06:26:30 pm »
I'm thinking I'll do as he did, warm it up and do a retorque.  However, I torqued them to 95lbs already, so I'll just go around and check.  I do the same thing with my turbo'd air cooled engine, with chromoly studs and they always snug down a little more after its been apart.
Jason
