Author Topic: Compression Test Specifications for AAZ engine  (Read 5631 times)
October 31, 2010, 10:01:24 am
erice1984
  • 263
« on: October 31, 2010, 10:01:24 am »
Was curious what Bentley says the compression tests should show for a normal engine and the wear limit.
1980 Rabbit 1.9TD
Reply #1October 31, 2010, 11:22:01 am
erice1984
  • 263
Re: Compression Test Specifications for AAZ engine
« Reply #1 on: October 31, 2010, 11:22:01 am »
Okay, I found a haynes manual and it states
Minimum: 279psi
Deviation: <20% from the highest reading
These are numbers from a US TDI motor.  I figured the compresion ratio is the same in both 1.9L TD and TDI so the sompression test specs would be the same.
Let me know if this is incorrect.
1980 Rabbit 1.9TD
Reply #2October 31, 2010, 11:56:50 am
« Reply #2 on: October 31, 2010, 11:56:50 am »
The TDI is a very different engine design, so the specs are not transferable.
The AAZ specs (Bentley pg 15a-2) are:
new:  493 psi minimum
wear limit: 377 psi minimum
max difference between cylinders: 73 psi
Reply #3October 31, 2010, 04:51:22 pm
erice1984
  • 263
« Reply #3 on: October 31, 2010, 04:51:22 pm »
Thanks for clarifying Vincent
1980 Rabbit 1.9TD
