Author Topic: rear window defogger  (Read 4797 times)
October 26, 2010, 09:09:21 am
dyoungen
  • 128
« on: October 26, 2010, 09:09:21 am »
I have a 1985 Diesel Jetta. The rear window defogger doesn't work at all. The light in the switch comes on but the window stays fogged up. I checked the wires connecting to the drfogger wireing and have voltage. I check the wireing in the window and there is continuity from end to end. With both of these I'm not sure why the defogger doesn't work.
Reply #1October 26, 2010, 09:28:38 am
Re: rear window defogger
« Reply #1 on: October 26, 2010, 09:28:38 am »
if youve got power to the switch, and power at the window.. and power going across the window, only thing left is the ground. That circuit needs to ground out for the current to pass through those tiny metallic strips and heat up.
Reply #2October 26, 2010, 09:29:01 am
« Reply #2 on: October 26, 2010, 09:29:01 am »
you and me both buddy. 85 gti, same EXACT problem..
Reply #3October 26, 2010, 01:25:52 pm
DCC
  • 184
« Reply #3 on: October 26, 2010, 01:25:52 pm »
Exactly.
I'd try to run a wire directly to ground and see if it works.
