Author Topic: anybody hear of this bio diesel that needs no mods to run  (Read 3198 times)
December 31, 2005, 10:33:33 pm
superman293
  • 93
« on: December 31, 2005, 10:33:33 pm »
i think it's called secret diesel engery, they claim you need no modifactions to your diesel, they sell a thinning agent to thin the cooking oil out, claims it cost 46 cent a gallon and there isn't any dangerous chemicals to mix, i was going to try it out but was wondering if anybody else new more about it.
thanks
Reply #1January 01, 2006, 07:28:06 am
QuickTD
  • 1156
« Reply #1 on: January 01, 2006, 07:28:06 am »
It is xylol, available at your local paint store for less than $20 a gallon. I'm bit skeptical regarding the claims, I think you would still have problems at below freezing temps.
Reply #2January 01, 2006, 07:46:54 am
bhtooefr
  • 305
    • http://my.opera.com/bhtooefr
« Reply #2 on: January 01, 2006, 07:46:54 am »
1986 Volkswagen Golf | 1.6L NA diesel | 5spd manual | Deep Cosmic Blue (LE5C) | aack, it's a parts car, now, too!
1992 Mazda Miata | 1.6L DOHC gasser | 5spd manual | Classic Red (SU)
Reply #3January 01, 2006, 08:06:23 am
superman293
  • 93
« Reply #3 on: January 01, 2006, 08:06:23 am »
doesnt really sound too great, i might give it a try this summer when the temp is up.
Reply #4January 01, 2006, 08:16:15 am
bhtooefr
  • 305
« Reply #4 on: January 01, 2006, 08:16:15 am »
I wouldn't, if I were you.
It's nearly as thick as SVO, from what I've read, and has a few very high octane components, making it a bad diesel fuel. (A fuel that has a high octane value resists compression ignition, so that one can crank up the compression ratio on a gasser. A fuel that has a high cetane number (read: good in a diesel) lends itself to compression ignition. Cetane and octane are near opposites.)
Reply #5January 01, 2006, 08:40:06 am
zyewdall
  • 393
« Reply #5 on: January 01, 2006, 08:40:06 am »
Yeah, like QuickTD said, it's a mixture of veggie oil, gasoline, and maybe some petro-diesel, and their secret ingredient, which is apparently Xylol.  I wouldn't call any of them except veggie oil non-dangerous.  In the summer time, maybe it'd be okay, but I wouldn't in mine.  SVO is cheaper ($0 per gallon once you have modified the vehical to heat the fuel).
I personally use regular biodiesel (both soy and canola based) without any modification to my vehical -- yes, it is $3/gallon, but I have never had any issues with it (aside from clogging my fuel filter with dirt it cleaned out of my system when I first switched).    I have also run SVO in vehicals -- you just have to get it to 160F or more before entering the injector pump in order to get the viscosity low enough (unless you have a mercedes with the in line pump -- people have run those on cold veggie oil without killing the IP)
Maybe it's just that I am an engineer, not a chemist, so I don't mind modifying the vehical to run SVO, and not have to deal with mixing chemicals, be they methoxide to make biodiesel, or gasoline to thin SVO.
'84 Mitsubishi 4x4 2.3L turbo biodiesel pickup
'91 VW Rabbit GTI with 1.6 biodiesel transplant
'81 Toyota longbed 2wd 2.2NA biodiesel pickup (for sale)
'89 Subaru 4x4 touring wagon
 '82 subaru 4x4 TDI wagon -- project on hold
1976 Ford Sasquatch pickup
Reply #6January 01, 2006, 09:43:19 am
superman293
  • 93
« Reply #6 on: January 01, 2006, 09:43:19 am »
so to run SVO there is no modifcations to the fuel, but you have make a way to heat it to 170 degress, is there any site or fourm you could point me to, i have a 1990 non turbo jetta, i would like to find out how much it would cost to convert my car
thanks
Reply #7January 01, 2006, 09:46:03 am
lesharoturbo
  • 78
« Reply #7 on: January 01, 2006, 09:46:03 am »
Superman,
Try http://www.greasel.com to start.
Bernie
Reply #8January 01, 2006, 09:46:43 am
bhtooefr
  • 305
« Reply #8 on: January 01, 2006, 09:46:43 am »
Elsbett, Greasecar, Greasel, Frybrid, and other companies sell kits, plus there's a few guides on making your own. Google is your friend.
FWIW, I've heard that Elsbett will warranty everything against damage from properly filtered fuel if you use their kit.
