General Information
Troubleshooting
WTB Audi 5000 TD Tach Issue
Topic: WTB Audi 5000 TD Tach Issue (Read 4587 times)
October 17, 2010, 11:10:44 pm
Toby
October 17, 2010, 11:10:44 pm »
I am looking for a wiring diagram for an '82 5000 TD that shows the tach wiring. No TD tach wiring in the factory manual, which seems odd. I have no oil light as well. It appears on the gas cars that the tach signal is needed for the magic oil pressure module to function. The car is new to me so I have no idea when this stuff last worked. I just swapped in a rebuilt motor and especially need the oil light to work. I do have pressure and a good switch. I am reluctant to tear into the dash cluster until I have a schemagic diagram unless the problem is in the alternator or attendant wiring. Any idea where I could find the overheat switch that goes in the back of the head?
TIA
Jason
October 18, 2010, 10:05:47 am
Re: WTB Audi 5000 TD Tach Issue
October 18, 2010, 10:05:47 am »
theres an overheat switch??
October 18, 2010, 11:25:49 am
Toby
October 18, 2010, 11:25:49 am »
Yes, it is the larger of the two senders in the back of the head. It turns on the "Overheating" light on the dash. The small one is the standard VPA temp sensor and it controls the glow plug duration.
October 19, 2010, 11:53:14 pm
Toby
October 19, 2010, 11:53:14 pm »
So no one here knows anything about VW/Audi diesel tach troubleshooting or has wiring diagram?
October 20, 2010, 03:03:14 pm
TPW
October 20, 2010, 03:03:14 pm »
Colectb has a Bentley, unless that is what you have already. That engine has two oil pressure senders, one on the lower drivers side of the engine, and the other on the oil pump on the front passenger side of the engine.
October 21, 2010, 10:59:32 pm
Toby
October 21, 2010, 10:59:32 pm »
I have the factory manual and it has nothing about the tach on a diesel, sad to say. The sender by the oil pump is an oil TEMP sender, not pressure. The oil light needs a tach signal to work the oil pressure module, so no tach, no light.
General Information
Troubleshooting
