Author Topic: Downpipe again  (Read 8277 times)
December 29, 2005, 02:11:03 am
zaprzal
  • 160
    • turbodiesel.pl
Downpipe again
« on: December 29, 2005, 02:11:03 am »
I have golf A2 GTD with SB engine (intercooled and 80HP), will 1.9 TD AAZ engine downpipe fit my engine? What diameter it has? Can I fit something else? Do you have any photos?
1.6td 170hp 290nm powered by Holset - sold
golf mk2 1.9tdi PD 193hp/400nm ;)
Reply #1December 29, 2005, 02:27:41 am
Maarten
  • 339
Downpipe again
« Reply #1 on: December 29, 2005, 02:27:41 am »
The downpipe will fit... but you'll have to adapt your exhaust to the different pipe. I suggest you stick with the 1.6GTD pipe (or go to a larger diameter if you need one)
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #2December 29, 2005, 03:10:03 am
zaprzal
  • 160
    • turbodiesel.pl
Downpipe again
« Reply #2 on: December 29, 2005, 03:10:03 am »
What diameter is 1.9 TD AAZ downpipe? Will 1.9 TDI 1Z (90hp) also fit me?
Reply #3December 29, 2005, 03:57:41 am
Maarten
  • 339
Downpipe again
« Reply #3 on: December 29, 2005, 03:57:41 am »
Ik don't know the diameter of the original 1.9 DP, I know the 1.6TD pipes are VERY restrictive (45mm internal diameter) so I swapped mine for a custom freeflow 70mm.
The turbo on a TDI is positioned different than a 1.6/1.9TD so that won't fit.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #4December 29, 2005, 05:06:51 am
Maarten
  • 339
Downpipe again
« Reply #4 on: December 29, 2005, 05:06:51 am »
this is a 1.9 downpipe...
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #5December 29, 2005, 05:53:18 am
zaprzal
  • 160
    • turbodiesel.pl
Downpipe again
« Reply #5 on: December 29, 2005, 05:53:18 am »
Ok, thanks. :) Is 1.9 td dp less restrictive than 1.6 dp? Is it worth to swap 1.6 dp for 1.9? Will it fit without any modyfications as I marked on picture? Only cut somewhere where I marked on picture and stick with rest of exhaust? Thanks for help
Reply #6December 29, 2005, 06:07:29 am
Maarten
  • 339
Downpipe again
« Reply #6 on: December 29, 2005, 06:07:29 am »
it looks less restrictive but I don't know the diameter of the pipe.. could be somewhere between 45 and 55 I think... If you cut it before the flex it could fit with some ghetto-welding ;) so I suggest a real upgrade  8)
This is my pipe:
on a K24 turbo (behind the pipe on the 2nd photo is the original dp)
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #7December 29, 2005, 07:30:48 am
zaprzal
  • 160
    • turbodiesel.pl
Downpipe again
« Reply #7 on: December 29, 2005, 07:30:48 am »
Last question: flange which I marked on picture is this same in 1.9 and 1.6 dp?
Reply #8December 29, 2005, 07:34:54 am
Maarten
  • 339
Downpipe again
« Reply #8 on: December 29, 2005, 07:34:54 am »
Yes it will fit.. on all IDI (1.6/1.9TD) turbos the outlets are the same...
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #9December 29, 2005, 07:39:48 am
andy2
Downpipe again
« Reply #9 on: December 29, 2005, 07:39:48 am »
Quote from: "zaprzal"
That downpipe pictured has a different flange used for the k03 turbo used on 1.9's from 95-97 I think.I have modified that pipe to fit on my 1.6td,the only thing you need to do is relocate the 2 bottom holes and cut the flange a little on the bottom.
If you can get a downpipe from a 93 and I think some 94's it will be a direct bolt on as those years used a k14 turbo which has the same bolt pattern as our 1.6 flange.
Other than that you'll have cut that flange off the exiting end and weld a peice of pipe onto it inorder to get the angle right underneath the car.
Reply #10December 29, 2005, 08:21:01 am
zaprzal
  • 160
    • turbodiesel.pl
Downpipe again
« Reply #10 on: December 29, 2005, 08:21:01 am »
I've got garrett T2
Reply #11December 29, 2005, 10:02:36 am
andy2
Downpipe again
« Reply #11 on: December 29, 2005, 10:02:36 am »
I believe that the T2 has the same outlet flange as the K14,K24 and T3.Mabye someone else could confirm this?
Reply #12December 29, 2005, 11:34:21 am
935racer
Downpipe again
« Reply #12 on: December 29, 2005, 11:34:21 am »
I've got a t2 on  a 1.9 in the shop right now, just checked, flange is the same as k14, k24, t3 etc
Reply #13December 29, 2005, 02:49:47 pm
Maarten
  • 339
Downpipe again
« Reply #13 on: December 29, 2005, 02:49:47 pm »
 :wink:
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
