Author Topic: New Head Install / With Extrude A Hone Polishing ( Plasma ) 1.9 AAZ  (Read 2311 times)
August 11, 2010, 03:13:27 pm
GEE-BEE
  • 1604
Installed the new head after plasma polished ( mirror internal finish )
New cam , valves, gasket , belt , ten
It's 60 % quieter than my last head assy ( motor / used mileage unknow ?
reduced smoke 40 %
Picked up 1.5 on boost compared to stock, temp is down a little bit also
it's a quiet as quiet as a TDI motor now !
It's like a new car !
I did replace the install all new shifter parts also  , tight as a  cable shift
next will be to relocate battery under bed and install intercooler with PD150
Relocating the battery will give me more room for outlet's, versus having to have extra plumbing for using a intercooler with dual outlets on one side
The PD150 was also extrude a honed polished like a mirror
« Last Edit: August 11, 2010, 03:45:06 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #1August 11, 2010, 03:40:53 pm
arnold
Re: New Head Install / With Extrude A Hone Polishing ( Plasma ) 1.9 AAZ
« Reply #1 on: August 11, 2010, 03:40:53 pm »
pics ? :)
Reply #2August 11, 2010, 03:46:08 pm
GEE-BEE
  • 1604
« Reply #2 on: August 11, 2010, 03:46:08 pm »
Nope
it's installed
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #3August 11, 2010, 05:25:57 pm
rallydiesel
  • 1880
« Reply #3 on: August 11, 2010, 05:25:57 pm »
That's nice but those numbers are entirely subjective.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4August 11, 2010, 06:34:08 pm
GEE-BEE
  • 1604
« Reply #4 on: August 11, 2010, 06:34:08 pm »
Iam just reading what my Mcnally gauges are showing
Mcnally's are accurate ( aircraft quality ) 265.00 each
I have the complete set
oil psi/ oil temp
Water / Volt
Boost psi / Egt
It's definetly not as loud, no as clacky as before  and less smoke, and the trans is perfect now
Iam happy and that's all that matters
Cost new head assy complete 250.00 in the box
Extrude a hone 575.00 for the intake PD150 and head assy
I know one other person that has seen it before and I will let him get his ear into it...
GB
Giles Pump OHC
MK1 JETTA DASH
