Author Topic: Max Boost Questions??  (Read 3628 times)
August 08, 2010, 12:04:12 pm
audi90sportq
« on: August 08, 2010, 12:04:12 pm »
Ive done all the necessary mods to reach above 13-15psi to my 1.6td, but I just cant seem to get above that pressure in 1st or 2nd gear?? 3rd i can hold a little above 15psi and 4th with peg 20psi, not that i want to run that much boost constantly, i feel that if i could hit 18psi in 2nd gear it would be...alot more fun?  ::) Could it be happening just because there is less load on the car in a lower gear?
Reply #1August 08, 2010, 12:11:48 pm
Re: Max Boost Questions??
« Reply #1 on: August 08, 2010, 12:11:48 pm »
That would be my guess... the engine needs to be working against a serious load to generate heat.  That's why you get little or no boost reving the engine at a red light.   ;)
One clue is that the factory test for boost specifies a hard pull up a hill in 3rd gear.
Reply #2August 08, 2010, 12:21:01 pm
audi90sportq
« Reply #2 on: August 08, 2010, 12:21:01 pm »
Ahhhhh, great info! One more quick question, what is the most popular mod to do, to get boost to come in quicker, or the turbo to spool faster? Ive turned in the screw on top of the LDA a little bit, Max fuel screw is in enough to where im out of idle adjustment  :P, Id just like boost to come in a bit sooner!
Reply #3August 08, 2010, 12:26:31 pm
rabbid79
  • 684
« Reply #3 on: August 08, 2010, 12:26:31 pm »
To help improve your spool, you need one of those valves on the WG line that doesn't allow the WG to start opening at all, until a certain minimum pressure has been reached.
'15 WRX
Reply #4August 08, 2010, 01:08:12 pm
« Reply #4 on: August 08, 2010, 01:08:12 pm »
^ This, and if you are running through stock exhaust, an upgrade will help your spool time a bit.
Reply #5August 13, 2010, 07:52:50 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« Reply #5 on: August 13, 2010, 07:52:50 pm »
which line is the WG line? theres 2 lines on mine, one going to the compressor housing and the other going somewhere else i kinda forgot
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #6August 14, 2010, 11:42:39 am
84tdrabbit
« Reply #6 on: August 14, 2010, 11:42:39 am »
the line from the comp housing to the WG is what your lookin for..
