Good sources and part numbers for Hydro Lifters.
Topic: Good sources and part numbers for Hydro Lifters. (Read 3999 times)
August 05, 2010, 10:25:58 am
August 05, 2010, 10:25:58 am »
My aaz ticks pretty darn loud and im not surprised. The lifters are from its father before it the 1.6td. I have no idea how old they are - probably anchient.
I saw a price for lifters in a catalogue for almost $40 each!!!
I'm sure there is something better out there - anyone know of any?
i found some at
www.germanautoparts.com
$8.50 each. Anyone know of somewhere closer to the west coast? Possibly in canada?
bah i got lazy and bought them anyways. I'd delete this post if i could ...
Last Edit: August 05, 2010, 03:32:57 pm by Smokey Eddy
Blue 2009 CR140 Jetta CBEA/CJAA. Malone stage 2. EGR/DPF/Exhaust-valve deletes. 2.5" open exhaust. ADP Turbo swap. 1-stage nitrous kit.
THROWN ROD
August 05, 2010, 10:32:31 am
Re: Anyone know of a source for Hydro Lifters?
August 05, 2010, 10:32:31 am »
9 bucks each from Bestpriceautoparts.com... but you already checked there, right??!! ;-)
August 05, 2010, 10:39:33 am
August 05, 2010, 10:39:33 am »
I did try bestprice, but they would only let me add 3 to my cart... it was messed up... no matter how many times i tried 8 it just wouldn't have any of it.
THROWN ROD
August 05, 2010, 11:09:24 am
rallydiesel
August 05, 2010, 11:09:24 am »
Maybe they only had 3 in stock. I'm sure they will get some more in.
1991 Jetta TD - sold
2001 Golf TDI - Son's
August 05, 2010, 11:50:02 am
August 05, 2010, 11:50:02 am »
Yup, that's exactly what that means... Worldpac in Canada is down to three... so you can't run next door to AutoPartsFirst or whatever other Canadian Worldpac guys you can find... you'll get the same answer. ;-)
It's a pretty common item so I'd expect it to replenish fast... although I once waited almost 2 weeks for a second control arm bushing...they are generally the cheapest source of OEM parts in Canada for our beasts.
You could also try Napa, since they carry most of Altrom's lineup. I also buy a lot of my TDI stuff from Brian at Roseland Technical Services in NS... great service and prices.
August 05, 2010, 03:30:07 pm
BAM
August 05, 2010, 03:30:07 pm »
Depending on what year your engine is the Napa/Altrom PN is 034 109 309 for 1993-05/96 and 050 109 309 H for 5/96-1998. I think the VW PN are 034109309AD and 050109309J. Here in ON there is 10 or more in stock depending on PN required
Last Edit: August 05, 2010, 04:06:43 pm by BAM
August 05, 2010, 03:33:29 pm
Re: Good sources and part numbers for Hydro Lifters.
August 05, 2010, 03:33:29 pm »
BAM just made this thread FAQ bound perhaps? Topic name changed accordingly.
THROWN ROD
August 06, 2010, 11:21:21 am
BAM
August 06, 2010, 11:21:21 am »
I can source almost any VW engine part. But I can only see stock in ON when I log on to the various catalogs. Post a new thread and I will get PN or whatever you need specs. etc.
August 06, 2010, 02:37:09 pm
August 06, 2010, 02:37:09 pm »
Do you mean a comprehensive list of all part numbers in text form that can be searched?
THROWN ROD
August 07, 2010, 07:26:13 pm
BAM
August 07, 2010, 07:26:13 pm »
What I mean is I will source what ever part you require and try to give you a possible point of purchase in your area. I do not deal in the USA to much but I have a good handle on Canada. If specs are required we can do that to. Wiring diagrams VW or otherwise. I do not want to step any vendors on toes here so I will not sell any parts unless you show up at my shop.
August 07, 2010, 09:28:47 pm
August 07, 2010, 09:28:47 pm »
Well you your self can be a vendor? there is nothing wrong with that.
THROWN ROD
Reply #11
August 08, 2010, 10:13:36 am
janb
Reply #11 on:
August 08, 2010, 10:13:36 am »
good cheap PNW (USA) source
http://halseyimportparts.com/
Maybe we should meet at
http://www.yelp.com/biz/edaleen-dairy-products-lynden
I get there as often as possible, but no plans in immediate future.
The Stealth Rabbit
VW-d's are forever
Reply #12
August 15, 2010, 07:08:53 am
32 VALVES
Reply #12 on:
August 15, 2010, 07:08:53 am »
just got some the other week for my 1z head, they are in New York...
Reply #13
August 15, 2010, 02:53:01 pm
Ziptar
Reply #13 on:
August 15, 2010, 02:53:01 pm »
Impex has 034109309AD for $10 each
and the
050109309J for $13.55
http://www.vwdieselparts.com/
sells a set of 8 for $129.95 ~$17 each.
