Author Topic: IP cold-start seal  (Read 5715 times)
July 15, 2010, 07:15:10 pm
motomike33y
  • 190
IP cold-start seal
« on: July 15, 2010, 07:15:10 pm »
need a seal for the cold-start lever shaft in my 82 NA injection pump.  Don't want to purchase a seal set, just that one.  Any place where I can order just that seal?  thanks
82 vanagon 1.6 waiting rebuild
81 jetta w/dasher 1.5 engine
91 jetta w/ 85 golf 1.6 NA- work in progress           suzuki samurai hardtop that may someday be diesel
2012 golf tdi
Reply #1July 17, 2010, 09:54:57 am
Re: IP cold-start seal
« Reply #1 on: July 17, 2010, 09:54:57 am »
its just a simple o-ring.. any parts store should have it..
Reply #2July 17, 2010, 10:08:58 am
« Reply #2 on: July 17, 2010, 10:08:58 am »
Any shop that will sell you the kit can also order the seal.
Reply #3July 17, 2010, 11:21:17 am
motomike33y
  • 190
« Reply #3 on: July 17, 2010, 11:21:17 am »
Thanks, I hadn't taken it apart yet, wanting to be able to reassemble promptly.
2012 golf tdi
Reply #4July 17, 2010, 11:38:05 am
« Reply #4 on: July 17, 2010, 11:38:05 am »
like i said, take it apart, and go to the hydraulic shop, or the nearest auto parts store. its just an o-ring. nothing special.
Reply #5July 18, 2010, 02:43:45 pm
OM617
« Reply #5 on: July 18, 2010, 02:43:45 pm »
Reply #6July 21, 2010, 05:34:57 pm
410
  • 581
« Reply #6 on: July 21, 2010, 05:34:57 pm »
I got an entire genuine Bosch seal kit from Giles for about $27ca if I remember correctly.  If the cold start seal is leaking, chances are the other seals are not far off.  Always good to have extra seals hanging around.  I think a regular o-ring would work.  Just remember that these pumps are metric with metric seals.
Reply #7July 21, 2010, 09:09:56 pm
« Reply #7 on: July 21, 2010, 09:09:56 pm »
For the amount of hassle in taking the pump off and timing it I would just use the proper o-ring. The Bosch one is harder then usual because of the daily movement of the cold start advance.
Reply #8July 22, 2010, 01:52:45 pm
« Reply #8 on: July 22, 2010, 01:52:45 pm »
nothing special.
Incorrect.
i went to the hydraulic shop, looked thru the metric o-rings, found the one that worked. and from what i can tell, its as good as what would have came in a kit. except it was FREE instead of having to buy a 50 dollar pump seal kit. and you know what? my pump cant tell the difference!
Reply #9July 23, 2010, 05:08:31 am
« Reply #9 on: July 23, 2010, 05:08:31 am »
yeah anything viton or diesel rated should be fine if it matches up.
