Author Topic: 95 AAZ Passat issues  (Read 3828 times)
June 29, 2010, 07:21:10 pm
patracy
  • 142
« on: June 29, 2010, 07:21:10 pm »
Here's a dandy issue I've had.  I was heading home and had to rev high to gain speed up the hill.  I revved it to redline.  Then it bogged and died.  Fearing the worse I drug it home only to find out I had no power to the IP.  So I hot wired it to a keyed +12V lead under the dash for the mean time.  Any idea what would have caused the power lead to the IP to loose power?  I've also noticed the fog lights no longer work.  :-\
Everything else works fine on the car though.  Windows, locks, AC, radio, turn signals, exc.
Reply #1June 29, 2010, 07:50:30 pm
  • 3255
    • My collection of HOWTOs
Re: 95 AAZ Passat issues
« Reply #1 on: June 29, 2010, 07:50:30 pm »
The IP is powered thru the Electronic Control Module... biggest black brick on the fuse panel on Jettas/Golfs... can't say for sure on the Passat chassis.
The line is unfused... so the most likely candidate is the module itself, or the wiring therein.
Do the glow plugs appear to be working OK??  They are also controlled by the ECM.
Reply #2June 29, 2010, 10:01:26 pm
Henchman
  • 183
« Reply #2 on: June 29, 2010, 10:01:26 pm »
Unless the 95 was different from the 93, I don't believe it even has an ECM. IIRC The shut off is controlled by the glow plug relay, which is controlled by the ignition switch.  I have had problems with Passat ignition switches where I have to push the key in and hold the plug on the back. So work forwards from the switch, to the relay, to the pump.
Ian
Under way - 1991 Passat Syncro Wagon w/m-tdi
1991 Passat GL Wagon w/AAZ conversion (now using engine/tranny from 1993 Passat
1993 Passat GL 1.9 Diesel (RIP 385k km, engine, tranny, clutch all original)
Reply #3June 29, 2010, 10:09:20 pm
  • 3255
« Reply #3 on: June 29, 2010, 10:09:20 pm »
Here's my understanding of the terminology:
ECM = electronic control module = analog circuit module that controls the glow plug relay, fast idle, EGR (if equipped) and supplies power to the AAZ's IP
Looks like this on a A3 Golf relay panel:
Not the same as the ECU... Engine Control Module... digital computer that controls a TDI's IP.
« Last Edit: June 29, 2010, 10:14:01 pm by Vincent Waldon »
Reply #4June 30, 2010, 07:05:28 pm
patracy
  • 142
« Reply #4 on: June 30, 2010, 07:05:28 pm »
Is the part number 05-3402-30 ?  Or does anyone know where I can get one?  Or any means to test it?
Reply #5June 30, 2010, 09:02:37 pm
Henchman
  • 183
« Reply #5 on: June 30, 2010, 09:02:37 pm »
I get what you're saying.  Just compared to a b3/b4 passat AAZ, the Mk3 AAZ is Big Blue.  None of that voodoo magic 136 business!
As for the relay, it's easy enough to check.  Relay 103 is compatible if IIRC.
Ian
Reply #6July 01, 2010, 01:07:21 pm
« Reply #6 on: July 01, 2010, 01:07:21 pm »
For what it's worth, the pump solenoid wire on my '94 AAZ Jetta is DEFINITELY fused.  The car has all the same "stuff" as the AAZ Passat would have.
How do I know it's fused?  I shorted it while the car was running.  No start after that.  Found a fuse labeled "Engine Management" or something like that, clearly blown.  Replaced, no issues.
Reply #7July 01, 2010, 05:30:42 pm
  • 3255
« Reply #7 on: July 01, 2010, 05:30:42 pm »
By george that rings a bell...some folks remove the Engine Management fuse as an anti-theft device... so stands to reason that it would control the ECM and thus power to the IP.
Good catch!
