1.9L Turbo off - eninge misfire's at higher RPMS
Topic: 1.9L Turbo off - eninge misfire's at higher RPMS (Read 3420 times)
June 18, 2010, 10:20:04 am
Golf/Jetta
June 18, 2010, 10:20:04 am »
1.9L TD, 97 Jetta
complete head rebuilt last year
no leaks nor oil missing/coolent
new injector's this year
glow plugs changed two years ago.
timing on the button
compression 390 - 410 PSI
no blue, white, black smoke
running with the turbo its fine @ higher RPMS but when the turbo's waste gate is opened (off) the engine misses at high RPMS..
i had the air box off during the winter months (conned filter) didn't misfire with this
then put it back on during the summer (K&N filter) and it misfires
what gives?
thought?
'97 Jetta - 4Dr - 1.9 TiDi (Forth Car)
'94 Jetta - 4Dr - 2.0L Swaped in an AZZ - Almost done 2011 b4 Winter (Third Car)
Blue '87 Golf - 2Dr - Tags (First Car)
Red '92 Jetta (W) - 4Dr - Sold to Friend For $200 (Second Car)
Thanx For Answering My Posted Question's/Comments...
June 18, 2010, 11:26:20 am
Re: 1.9L Turbo off - eninge misfire's at higher RPMS
June 18, 2010, 11:26:20 am »
i think its probably a miss firing injector. my audi does the same thing above like 4000. real loud popping and it smokes..
June 18, 2010, 01:22:35 pm
dankcorey22
Cummins!
June 18, 2010, 01:22:35 pm »
It may be the fuel. you dont have enough fuel going to the pump at those RPM's. To solve: Get a lift pump
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
June 18, 2010, 03:52:03 pm
June 18, 2010, 03:52:03 pm »
A lift pump is a band-aid. It's not really solving the problem.
June 18, 2010, 09:55:05 pm
Aki-76
June 18, 2010, 09:55:05 pm »
i think itīs lda.when waste gate opened,boost go sini wave and lda get inaccurate feed.
June 19, 2010, 10:22:59 am
June 19, 2010, 10:22:59 am »
wow, this thread drew a response from Aki, thats surprising.
June 19, 2010, 10:22:16 pm
Aki-76
June 19, 2010, 10:22:16 pm »
June 20, 2010, 02:36:48 pm
June 20, 2010, 02:36:48 pm »
Do you have a lot of bubbles at the fuel line. If so, replace your fuel filter and check all the fuel line connections.
Or as Aki-76 said, the LDA is not working or is not getting it's vacuum signal from the intake manifold. Is the small hose bad/disconnected/missing/collapsing from vacuum?
