Author Topic: Source for rod and main cap bolts--04 Pump Duce motor  (Read 2982 times)
June 15, 2010, 07:55:14 am
AudiVWguy
« on: June 15, 2010, 07:55:14 am »
I have an  BEW pump duce motor from an 04 Jetta. The motor came from a tech at the dealership. The customer cracked the oil pan, but immediately shut the engine off. Against the techs advice they put in a different motor out of the junk yard. I bought the motor from the tech to put into a caddy, not realizing that I would have to "reinvent the wheel" to get this to fit into the car. I know it could be done, but its more work than I want to take on. I'm going with an AAZ swap instead.
Anyway, upon inspection the motor looks fantastic, no problems in the bearings or cam, super clean. I made some calls to the dealerships and they said the bolts are not reusable (like head bolts). I am looking for a source of replacement bolts for the rods and mains. The dealer parts guy had a hard time finding the part numbers and said the rod bolts are $16.00 each. Still getting back to me on the mains. Does this seem a bit high?  If anyone has a sources for these let me know.
Thanks for the help,
-Jeff
Reply #1June 15, 2010, 09:55:13 am
MJF
  • 581
Re: Source for rod and main cap bolts--04 Pump Duce motor
« Reply #1 on: June 15, 2010, 09:55:13 am »
Main bolts are same as other engines, AM10x80mm (N  90130001 ~1,25€/each) Rod bolts M8x1x44mm (045105425 ~4,1€/each) Prices are in Finland, $16/each sounds a bit high...
'74 VW Scirocco TD
'86 Audi 80q 1,9TDic
'01 Audi A6q 2,5TDI
Reply #2June 15, 2010, 03:46:54 pm
AudiVWguy
« Reply #2 on: June 15, 2010, 03:46:54 pm »
Yeah,
I thought that was a bit high too. I know a place that specializes in metric bolts. What is the bolt quality spec (grade of bolt) I should ask them for? Other wise ARP bolts might be cheaper.
Reply #3June 16, 2010, 04:43:10 am
MJF
  • 581
« Reply #3 on: June 16, 2010, 04:43:10 am »
Main bolts are 10.9, i've used regular 12.9 bolts. Rod bolts are special.
'74 VW Scirocco TD
'01 Audi A6q 2,5TDI
