Author Topic: Governer Mod HELP!! Did I mess something up!?  (Read 2261 times)
June 09, 2010, 07:39:41 am
Sampson
  • 4
« on: June 09, 2010, 07:39:41 am »
I performed my Governer mod las tnight - Spacing only the main spring by 4mm.
Now. It wouldn't start at first - I had to up the fuel and raise the idle to get it to start and stay running. (800rpm)
I then test drove - No smoke, Less power, A lot less boost. (before I modded i had smoke, lotsof smoke)
So I upped the fuel to the point where it would idle at 1000rpm. It was a little better - a bit more smoke and a bit more power. But still no where near what I expected. I feel that it was faster before.
NOW
I was jsut out on my lunch and it tried to run away in first gear. Too much fuel is my first suspicion but I have no smoke, no power and like 6 psi less boost. I am faily knoledgeable on these engines - But I am at a loss. I double check i got everything back on as it was prior to the mod.
Anyone have any ideas?
I am going to take it back apart tonight to ensure I have everything hooked up properly inside the pump.
Reply #1June 09, 2010, 08:38:23 am
Re: Governer Mod HELP!! Did I mess something up!?
« Reply #1 on: June 09, 2010, 08:38:23 am »
did you maybe put your throttle on in the wrong position
Reply #2June 09, 2010, 10:07:44 am
« Reply #2 on: June 09, 2010, 10:07:44 am »
thats my bet. missed by a spline or 2..
Reply #3June 10, 2010, 03:16:46 am
Sampson
  • 4
« Reply #3 on: June 10, 2010, 03:16:46 am »
And this is why I love this place!
After a closer inspection and cleaning all the paint off my throttle plate - It was most definitely off one tooth. Set it up again and the car is now a beast!
Thanks again!
Reply #4June 10, 2010, 01:57:30 pm
« Reply #4 on: June 10, 2010, 01:57:30 pm »
awesome we now deserve a movie
Reply #5June 11, 2010, 08:30:03 am
catlin_cava
  • 1954
« Reply #5 on: June 11, 2010, 08:30:03 am »
Yup, I must see what this car looks like in motion, it looked pretty sweet at MVOC ;)
Catlin
2010 VW Golf City 2.0L "Hers"
