Author Topic: glowplugs?  (Read 4387 times)
June 08, 2010, 12:22:33 pm
Vohaul
  • 105
glowplugs?
« on: June 08, 2010, 12:22:33 pm »
Hi,
I have a 94 aaz turbo diesel....and recently all of a sudden, started being very hard to start when cold.20 - 30 secs of turn over then coughs to life with white smoke out the tail pipe (unburnt fuel?)..as soon as it fires, its fine...runs great, lots of power etc. and if i shut it off and turn it back on again, its 1st turn of the key....
also, when it first fires..if i push in the cold start knob, it stumbles etc. until its been running for a minute....all like it was cold outside...but it isnt....its +10 -+15 c
any ideas?
Cheers
Paul
Reply #1June 08, 2010, 12:54:53 pm
Re: glowplugs?
« Reply #1 on: June 08, 2010, 12:54:53 pm »
IDI engines need some glow plugging even on temperate days, and since this happened "all of a sudden" it certainly sounds like it could be glowplugs... some troubleshooting info here:
http://vincewaldon.com/index.php?option=com_content&task=view&id=41&Itemid=28
Reply #2June 09, 2010, 02:13:22 pm
Re: glowplugs?
« Reply #2 on: June 09, 2010, 02:13:22 pm »
While you are poking around under the hood check to make sure that the crank gear isn't starting to slip. It's as easy as removing the cam cover and verifying that the cam and crank are still in time with each other.
Odds are it is just a glowplug issue like Vince said though
Reply #3June 09, 2010, 03:35:31 pm
Vohaul
  • 105
Re: glowplugs?
« Reply #3 on: June 09, 2010, 03:35:31 pm »
Ya, i'm pretty sure its not that as when the car is running it is super smooth and powerful as usual......
Reply #4June 12, 2010, 09:59:07 pm
Vohaul
  • 105
Re: glowplugs?
« Reply #4 on: June 12, 2010, 09:59:07 pm »
sigh...i dont get it.....now the car starts fine....a little pull of the cold start handle..and 1st turn of the key....i didnt get a chance to even do anything:)
Reply #5June 13, 2010, 06:47:33 am
Re: glowplugs?
« Reply #5 on: June 13, 2010, 06:47:33 am »
That sounds like air in the fuel system to me.
Reply #6June 14, 2010, 10:11:23 am
Vohaul
  • 105
Re: glowplugs?
« Reply #6 on: June 14, 2010, 10:11:23 am »
could it be bad diesel.....?
now that i think about it, it went away after i filled it up.....
