Author Topic: Mileage 1.6 NA  (Read 7291 times)
June 08, 2010, 11:04:25 am
JGVWDiesel
  • 55
Mileage 1.6 NA
« on: June 08, 2010, 11:04:25 am »
Hey all, I'm just going to ask if this is reasonable mileage given my conditions. I'm getting about 35 mpg in the city (I only drive city right now) and I go up several very large grade hills everyday as well as having to go down them. I have a lot of stop and go because all the lights, as well. The engine is a 1.6 NA with 363k on it with what seems to be original injectors and pump. It smokes a fair bit above 75%ish throttle. All the wheels spin pretty freely when lifted, so they're not an issue. The biggest and longest hill I have to climb is a 10% grade over just under 2 kilometers. There's a couple more small ones between 7 - 10% as well.
Just wanted to see what others thought about my mileage given what I have to drive each day.
Reply #1June 08, 2010, 02:02:23 pm
Wayland
  • 364
Re: Mileage 1.6 NA
« Reply #1 on: June 08, 2010, 02:02:23 pm »
That seems really low to me. I'm assuming your mpg figures are calculated using imperial gallons, not US? My Jetta still got 53mpg, albeit mostly highway when the injectors were really bad.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #2June 08, 2010, 06:34:07 pm
JGVWDiesel
  • 55
Re: Mileage 1.6 NA
« Reply #2 on: June 08, 2010, 06:34:07 pm »
No I was using US MPG. In imperial MPG I'm getting 42.2 MPG. Are most people using imperial on here or something?
Reply #3June 08, 2010, 07:37:45 pm
Wayland
  • 364
Re: Mileage 1.6 NA
« Reply #3 on: June 08, 2010, 07:37:45 pm »
I live in Canada, so I use imperial gallons. I assumed that since you also live in Canada, you would too.
93 Dodge CTD Truck
Reply #4June 08, 2010, 07:38:07 pm
Re: Mileage 1.6 NA
« Reply #4 on: June 08, 2010, 07:38:07 pm »
AFAIK US mpg is used most.
I'd say that's a bit low, what year/car is this? If it's a mk1 style then the odometer is known to slip and miss about a .1mi per mile causing it to show lower mpg than you're really getting.
Reply #5June 08, 2010, 08:20:08 pm
JGVWDiesel
  • 55
Re: Mileage 1.6 NA
« Reply #5 on: June 08, 2010, 08:20:08 pm »
86' american built golf 1.6 NA. The speedo does tend to bounce around a bit in the lower speeds, if that can count for much.
Reply #6June 09, 2010, 01:06:06 pm
clbanman
  • 705
    Cambridge, Ontario
Re: Mileage 1.6 NA
« Reply #6 on: June 09, 2010, 01:06:06 pm »
91 Golf 1.6 NA 5spd.  I have averaged 46.64 mpg (Imp) or 5.81 l/100km since Sept. 2009  (7550 km).    514,000 km, only modification that I know about is 2.25" exhaust.  Not sure which tranny I have but it is geared much lower than my 86 Golf and gets about 200 km per tank less.    I beat on it a fair bit which makes a difference too.
Calvin
91 VW Golf 1.6NA 5spd
Reply #7June 09, 2010, 06:43:16 pm
Re: Mileage 1.6 NA
« Reply #7 on: June 09, 2010, 06:43:16 pm »
I was getting around 5.4-5.2l/100kms in my mk2 NA. That was about 50/50 highway/city.
When you drive do you keep the RPMs up or put it in the tallest gear you can without lugging it?
Reply #8June 09, 2010, 09:14:39 pm
JGVWDiesel
  • 55
Re: Mileage 1.6 NA
« Reply #8 on: June 09, 2010, 09:14:39 pm »
i try to hit the tallest gears I can without having to lug it around. i'm also a heavy guy and I'm also usually with my gf as well.
Reply #9June 09, 2010, 11:21:37 pm
Re: Mileage 1.6 NA
« Reply #9 on: June 09, 2010, 11:21:37 pm »
I can still hit ridiculous numbers with a fully loaded car (four people and our stuff in the trunk... packed full, have to sit on the trunk to close).. I usually try and keep it up there around what feels like 30-3500 rpm if I need any power, but if not its the tallest gear.
Reply #10June 10, 2010, 08:46:14 am
JGVWDiesel
  • 55
Re: Mileage 1.6 NA
« Reply #10 on: June 10, 2010, 08:46:14 am »
Its also hard to tell but it SEEMs like I get a slight bit more grunt with the cold advance lever pulled out. You can definetely hear the difference when it's cold but its harder when warm. I wonder if that means my inj pump should be advanced some??
Reply #11June 10, 2010, 08:51:29 am
Re: Mileage 1.6 NA
« Reply #11 on: June 10, 2010, 08:51:29 am »
A little more advance is never a bad thing, especially if your still sitting at stock numbers. I have my n/a timed to 1.03mm
Reply #12June 10, 2010, 09:16:32 am
Re: Mileage 1.6 NA
« Reply #12 on: June 10, 2010, 09:16:32 am »
Since you are mainly in town try and keep the RPMs one gear higher (if it sounds realistic) for a tank and see if that effects your mileage any.
Reply #13June 10, 2010, 10:32:21 am
JGVWDiesel
  • 55
Re: Mileage 1.6 NA
« Reply #13 on: June 10, 2010, 10:32:21 am »
Ok, I'll be coming up to my next tank in a bit here. ( really odd going over 2 weeks on a tank, im not used to it haha.)
One thing I'm curious about with these kind of fuel injection systems is do they cut fuel in decel like a efi gas engine does or something else? I tend to use my engine braking just about every hill I get to, could this be adversely affecting my mileage?
Next tank I want to try to introduce a few different things to my driving style to see how it changes it.
Also, what size would my fuel tank be if it's an american built 86 diesel golf?
Reply #14June 10, 2010, 10:33:30 am
JGVWDiesel
  • 55
Re: Mileage 1.6 NA
« Reply #14 on: June 10, 2010, 10:33:30 am »
i often forget this, but thanks for all your guys help so far. it's kind of odd that i'm driving to get the most fuel as I can where as before in my previous vehicle I was tuning it to get the most power out of it as I could but was getting a pathetic 17 mpg :P
