General Information
General
Mileage 1.6 NA
Pages:
Topic: Mileage 1.6 NA (Read 7320 times)
Reply #15
June 10, 2010, 01:22:25 pm
Re: Mileage 1.6 NA
Reply #15 on:
June 10, 2010, 01:22:25 pm »
i believe you have a 50-55L tank iirc. The mk1's (pre-85) have a 40L
it is odd going a long time on one tank eh? I found this odd when i switched over to diesel as well.
Fueling is based on the pedal from what i have read.. You need to push the pedal for the governor to pull the flyweights over to start injecting fuel. I would think with no pedal input it is merely injecting the bare minimum per cylinder to sustain combustion at that rpm.
Reply #16
June 10, 2010, 02:13:23 pm
Re: Mileage 1.6 NA
Reply #16 on:
June 10, 2010, 02:13:23 pm »
In conditions where the vehicle is driving the engine the pump is not injecting any fuel.
Reply #17
June 10, 2010, 03:16:28 pm
JGVWDiesel
Re: Mileage 1.6 NA
Reply #17 on:
June 10, 2010, 03:16:28 pm »
50-55l? is there a specific? it would be nice to know for when I fill up before emptying the tank to tell how much I have left for reference.
it is odd for sure.
ok, cool. so I guess using engine braking isn't really an issue then.
Reply #18
June 10, 2010, 03:23:18 pm
Re: Mileage 1.6 NA
Reply #18 on:
June 10, 2010, 03:23:18 pm »
Quote from: burn_your_money on June 10, 2010, 02:13:23 pm
My tach is run by transducer clamped onto the injector pipe and when I coast above about 3000rpm the tach quits reading. If it's much below that it'll still read.
Reply #19
June 11, 2010, 11:07:20 am
JGVWDiesel
Re: Mileage 1.6 NA
Reply #19 on:
June 11, 2010, 11:07:20 am »
interesting. how hard was that to do?
can anyone chime in as to what the exact tank size is? thanks!
Reply #20
June 11, 2010, 01:33:18 pm
JGVWDiesel
Re: Mileage 1.6 NA
Reply #20 on:
June 11, 2010, 01:33:18 pm »
I forgot to mention, I also have power steering. (which seems to be leak at the reservoir, but even with good amount of fluid it still squeels on first starts.)
Pages:
General Information
General
Mileage 1.6 NA
