Author Topic: Safe RPM  (Read 9550 times)
December 06, 2005, 08:47:03 pm
T-hane
  • 15
Safe RPM
« on: December 06, 2005, 08:47:03 pm »
In my car i have the a gear box code of AGS and i find the gear ratio to be great for driving in town.  But on the hi-way at 120km the car is at 3000rpm is that kind of rpm safe for long periods of time?
Reply #1December 06, 2005, 09:04:24 pm
QuickTD
  • 1156
Safe RPM
« Reply #1 on: December 06, 2005, 09:04:24 pm »
3000rpm is fine. I routinely cruise for hours at 3200rpm (135km/h) on the highway. My car now has 285000km on it, consumes no oil and starts instantly at -25ºC.
VW industrial engines are often set up to run 3600rpm on 2 pole generators, they run at this speed under full load for years, not fun to listen to but it doesn't appear to harm them... I wouldn't sweat it.
Reply #2December 07, 2005, 03:28:06 am
Black Smokin' Diesel
  • 656
Safe RPM
« Reply #2 on: December 07, 2005, 03:28:06 am »
It's actually more harmful to an engine to leave it idling for hours than driving it on the highway. Unless you're scared that the timing belt won't survive or you have cooling problems, there's really no problem.
Reply #3December 07, 2005, 05:21:03 pm
T-hane
  • 15
Safe RPM
« Reply #3 on: December 07, 2005, 05:21:03 pm »
at that rpm what should i be seeing for fuel millage im  only gettng about 550 to a tank right now running 3000rpm on the hi-way.
Reply #4December 08, 2005, 02:10:52 am
NOTORIOUS VR
  • 83
Safe RPM
« Reply #4 on: December 08, 2005, 02:10:52 am »
Hmmm... I'd like to know as well.. I have the 4S tranny in my car (or so it says on the housing of the tranny), and @ 120 km/h i'm at 3200 rpm... which I thought is a little high...
Anyone else here with a 4S tranny that can confirm? 8)
Reply #5December 08, 2005, 10:38:25 am
carrizog60
  • 978
Safe RPM
« Reply #5 on: December 08, 2005, 10:38:25 am »
i also have a 4S but at the moment the car is being rebuited and i never drive it before...
120km/h at 3200 it´s kind high...
 :cry:
Portugal
Reply #6December 08, 2005, 11:28:27 am
Mark(The Miser)UK
  • 1557
Gearbox check
« Reply #6 on: December 08, 2005, 11:28:27 am »
Why not lift one front wheel and put it into 5th gear and check for one crank revolution whilst turning wheel...
Mark-The-Miser-UK
Reply #7December 09, 2005, 01:47:18 pm
Dr. Diesel
  • 1341
Safe RPM
« Reply #7 on: December 09, 2005, 01:47:18 pm »
i put the 3.67:1 ring and pinion in, and an .71 fifth gear. 2450 rpm at 100km/h.
Reply #8December 09, 2005, 02:10:59 pm
BlackTieTD
  • 1512
Safe RPM
« Reply #8 on: December 09, 2005, 02:10:59 pm »
about time! we should go for another hwy drive now.  :)
Reply #9December 09, 2005, 02:55:37 pm
Safe RPM
« Reply #9 on: December 09, 2005, 02:55:37 pm »
Wouldn't it be nice to have a 6 speed tranny?
http://www.autoshoppingcenter.com/Volkswagen/transmissions_rearend/trans_6speed.html
these would fit pretty much all mkII right? $$$$$$$$$$ though :(
btw, I used to drive a 3 speed automatic golf gas...  3500 rpm at 100km/h very low mpg :(
Reply #10December 09, 2005, 02:58:38 pm
Maarten
  • 339
Safe RPM
« Reply #10 on: December 09, 2005, 02:58:38 pm »
6-Speed Race transmission
Race transmission for 4 Cylinder applications.
Custom 1st through 6th gears
limited slip differential installed
I'll take this one, take away please  :roll:
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
Reply #11December 10, 2005, 12:31:34 am
djteam
  • 3
Safe RPM
« Reply #11 on: December 10, 2005, 12:31:34 am »
Hi,
I took an Tranny of an 90HP TDI Engine, now i´m at about 150km/h@3200.
It´s a cheap way to get RPM down.
christian
Jetta MKII 1,9L IDI @15Psi, IC, Oilcooler, TDI Tranny(CYP - 147km/h@3200), powered with 100% rapeseel oil.
Reply #12December 10, 2005, 09:38:30 am
VWRacer
  • 649
Safe RPM
« Reply #12 on: December 10, 2005, 09:38:30 am »
Just a note to those enchanted with the idea of a 6-sp manual trans...the only real advantage of 6 gears over 4 or 5 is in racing where more gears allows for better acceleration. For maximum economy the primary factors are the r&p ratio (lower number is better), the top gear ratio (lower number is better) and the drive-wheel diameter (higher number is better). Dr Diesel's solution above will yield the best fuel economy, no matter the allowed top speed.
Stan
C-Sports Racer
Reply #13December 11, 2005, 12:18:40 pm
Safe RPM
« Reply #13 on: December 11, 2005, 12:18:40 pm »
Quote from: "djteam"
Hi,
christian
How much did that cost you?  Which TDI trans will fit a MKII IDI engine???  Sounds like it could be a simple swap :)
Reply #14December 12, 2005, 01:49:03 am
NOTORIOUS VR
  • 83
Safe RPM
« Reply #14 on: December 12, 2005, 01:49:03 am »
Any 4cyl VW tranny will fit another 4cyl VW engine... the only thing I could see that you'd have to change is the pedals for the newer hyrdo tranny.
