Author Topic: Dynamic timing and High EGTS  (Read 3047 times)
May 30, 2010, 10:40:38 am
camboscams
  • 324
« on: May 30, 2010, 10:40:38 am »
Well when i got my new Giles pump i timed it to .85, as per giles instructions , and i can hardly do 65 mph and not keep it under 1000 degrees on the pyro.... so i called him and he said that maybe if i took some dynamic timing out of the pump it might help. so i shimmed it about a mm and no change on the highway. So im kinda at a loss of what to do.
Its a 1.6l turboed 155bar injectors
Cambo
81' White 1.6l Rabbit 4dr Holseted
72' Ford F-250 390cid
2014 JSW 2.0L TDI Stg 2, CP3 HPFP
Reply #1May 30, 2010, 10:42:53 am
  • 3255
    • My collection of HOWTOs
Re: Dynamic timing and High EGTS
« Reply #1 on: May 30, 2010, 10:42:53 am »
How much boost are you running??  Within limits, more boost = lower EGTs.
« Last Edit: May 30, 2010, 10:44:47 am by Vincent Waldon »
Reply #2May 30, 2010, 11:57:18 am
camboscams
  • 324
« Reply #2 on: May 30, 2010, 11:57:18 am »
14psi with no black smoke just a light haze
Reply #3May 30, 2010, 12:41:08 pm
rabbitman
  • 2788
« Reply #3 on: May 30, 2010, 12:41:08 pm »
.85mm is crazy retarded, most people run 'em .95-1.05mm.
I'd for sure be advancing the static timing before messing with the dynamic stuff.
Reply #4May 30, 2010, 03:44:11 pm
camboscams
  • 324
« Reply #4 on: May 30, 2010, 03:44:11 pm »
I agree that it is quite retarded..... But thats exactly what Giles told me to time it ata
Reply #5May 30, 2010, 04:52:46 pm
« Reply #5 on: May 30, 2010, 04:52:46 pm »
Exactly how mine acted when I had it 180 out.
Reply #6May 30, 2010, 05:37:17 pm
« Reply #6 on: May 30, 2010, 05:37:17 pm »
That was my first thought as well.
On a 1.6 I would time it to 0.90
Reply #7May 30, 2010, 09:09:12 pm
camboscams
  • 324
« Reply #7 on: May 30, 2010, 09:09:12 pm »
Just retimed it 180 degrees from how it was. The egts were much lower and i got my injection knock back, as where before it sounded pretty smooth. My only problem is that now its got a little more grey smoke at idle. and its kinda gutless and it takes alot more to get it get it to build full boost. but i guess the next thing i should do is reverify all my timing marks and pump timing
Reply #8May 31, 2010, 12:02:07 pm
rabbitman
  • 2788
« Reply #8 on: May 31, 2010, 12:02:07 pm »
I'm perdy sure grey smoke at idle is from retarded timing, I'd time it to where it runs the best.
