Author Topic: bigger injectors for 1.6 td  (Read 9698 times)
May 22, 2010, 09:30:02 pm
dankcorey22
  • 379
    Cummins!
    • Anything that runs
« on: May 22, 2010, 09:30:02 pm »
i have 2 questions to ask
number one is the injectors on a mercedes benz 300 turbo diesel bigger than the ones on the 1.6 td's?
Number two does it produce more power if the MB injectors are in the 1.6 TD? And are they interchangeable?
Thanks Corey
MY CARs-BLACK 99.5 Jetta TDI 5 speed 93,000- DC Stage 2 Clutch Kit 14Lb FW, Afe air intake box, 2.5" DP, 11mm IP, 2.5" stright piped, boost gauge, PP764, RC5 (WOW), 3-Bar, McNally EGT/Boost, 17/22, Race Pipe, EGR Cooler Delete, PD lift pump, R32 MAF housing,FMIC
1983 VW Jetta 1.6 turbo fuel mods
Reply #1May 23, 2010, 06:40:32 am
Re: bigger injectors for 1.6 td
« Reply #1 on: May 23, 2010, 06:40:32 am »
Stock nozzles can provide the fuel your engine needs.
There have been stories of MB nozzles knocking the precups out of the head. They are designed for a totally different precombustion chamber.
Reply #2May 23, 2010, 06:52:05 am
macka
  • 957
« Reply #2 on: May 23, 2010, 06:52:05 am »
not bigger physically, but GTD injectors are a nice upgrade
Quote from: Vincent Walden
Reply #3May 23, 2010, 10:29:46 pm
dankcorey22
  • 379
    Cummins!
« Reply #3 on: May 23, 2010, 10:29:46 pm »
alright thanks guys for the help ill probably get some from the junk yard with not many miles on em and try the injectors.
Reply #4May 24, 2010, 09:30:25 am
« Reply #4 on: May 24, 2010, 09:30:25 am »
the merc ones? your actually gonna use them? dont come back here crying if they render your engine useless... we already told you the potential side effects of merc nozzles.. go with something that designed for a VW pre chamber.
Reply #5May 24, 2010, 10:21:38 am
dankcorey22
  • 379
    Cummins!
« Reply #5 on: May 24, 2010, 10:21:38 am »
what about these- http://dieselvw.com/16TDMercedesInjector.htm
There Merc spec injectors just a spray pattern for the VW pre chamber
Reply #6May 24, 2010, 11:40:08 am
« Reply #6 on: May 24, 2010, 11:40:08 am »
Do a search for "prothe" before you buy anything from that site.
Reply #7May 24, 2010, 03:46:29 pm
« Reply #7 on: May 24, 2010, 03:46:29 pm »
there merc injectors that prothe sells to install in a VW. there not the right injector. and 99% chance that they are cheap chinese junk. go with either stock, or GTD nozzles.
Reply #8May 24, 2010, 04:11:36 pm
« Reply #8 on: May 24, 2010, 04:11:36 pm »
No, these are "VW" housings (which is irrelevant) with Merc nozzles eg. NOT for VW prechamber.
If you are running veg or bio dirty enough to foul stock injectors, different ones are not going to help you for long.
All the housings are the same, nozzle and spring setting change with application.
Reply #9May 26, 2010, 07:32:07 am
subsonic
  • 1836
« Reply #9 on: May 26, 2010, 07:32:07 am »
I wonder how the merc nozzles would do on a bio or grease engine?  I remember reading somewhere that for best use (grease) they switched nozles to slightly bigger.
Reply #10May 26, 2010, 08:29:24 am
« Reply #10 on: May 26, 2010, 08:29:24 am »
only non-vw nozzle i would run is a GM nozzle. the pre chambers are damn near identical to a VW. ive heard of someone else installing gm nozzles too, and we never heard any bad feedback about them..
