Author Topic: WTT 90 mm for 100mm  (Read 4818 times)
May 20, 2010, 07:48:42 pm
WTT 90 mm for 100mm
« on: May 20, 2010, 07:48:42 pm »
WTT
I have a set of 90mm cv axles for MKII jetta. I need a set of 100mm cv axles for the same jetta. The ones I have are good, just want a good set for even swap if possible. If not let me know what the deal would be. Thanks Lucas><>
Reply #1May 20, 2010, 08:32:17 pm
Dakotakid
  • 1240
Re: WTT 90 mm for 100mm
« Reply #1 on: May 20, 2010, 08:32:17 pm »
Better sell him some big ball joints and spindles, too....ehh?
Reply #2May 21, 2010, 06:30:53 am
« Reply #2 on: May 21, 2010, 06:30:53 am »
Oh no, what all do I need to do this. I was thinking that all I needed were the flanges and new axles. Everything else upgrade later? Please tell me I am correct. I have a set of 100mm flanges I got for free:D
Reply #3May 21, 2010, 07:43:34 am
« Reply #3 on: May 21, 2010, 07:43:34 am »
Depending on what day it was when they assembled your Jetta, the outer 100mm's might not fit in your stock spindles.  I've heard people say that they only put the smaller spindles on the 90mm cars and the larger ones on 100mm cars, but I've seen a few 90mm cars with the larger spindles.
At least with the larger spindles, you can more easily use the 16v front brakes.   ::)
I wish I could remember how to tell the difference without actually looking at both spindles....
Reply #4May 21, 2010, 07:49:01 am
« Reply #4 on: May 21, 2010, 07:49:01 am »
I just got this email and I don't know what to think. I guess if all else fails I could either swap the inner cv on the axle I have or change back to the 90mm hub.
           """""I thought they were the same, so I checked ETKA, and it shows only one part number for the knuckle and the hub for the German built 86 Jetta. On the same diagram (the axles and knuckles are in the same drawing) it shows both 90mm axles and 100mm axles for the RD engine (same engine in my 86 GTI).
This tells me the one part number for the knuckle is for all versions of the 86 Jetta, including those equipped with the RD engine and 100mm axles.
With all that being said... I think they are the same, but I would verify from more sources before making a decision.... I know the 020 pretty well, but the various changes in the models I do not so get more opinions if you can.
I checked the part numbers against the 86 GTI and they're the same. I know for a fact some of them came with 100mm axles so I see no reason why your 86 Jetta with the exact same front parts as my 86 GTI, wouldn't accept 100mm axles""""
I just hope it works. Either way anyone have some cv's?
« Last Edit: May 21, 2010, 05:33:37 pm by theman53 »
Reply #5May 21, 2010, 07:36:19 pm
« Reply #5 on: May 21, 2010, 07:36:19 pm »
Worst case, could I buy a 100mm inner and swap the inner off my axle?
Reply #6May 24, 2010, 07:46:48 am
« Reply #6 on: May 24, 2010, 07:46:48 am »
my rabbit has 100mm inners and 90mm outters. works great. you do not want to buy individual CV joints tho.. someone quoted me over 100 bucks for just the joint alone.
Reply #7May 24, 2010, 07:52:34 am
« Reply #7 on: May 24, 2010, 07:52:34 am »
yeah, at least I have that option. I still need 100mm shafts though. Anyone want to come off some or even have some?
Reply #8May 24, 2010, 08:09:56 am
« Reply #8 on: May 24, 2010, 08:09:56 am »
90 and 100mm shafts should be the same.
Reply #9May 24, 2010, 08:57:42 am
ilikevwdiesel
  • 1202
    • Erupt into a BEVRAGE this summer with Glug!
« Reply #9 on: May 24, 2010, 08:57:42 am »
I have a set of axles from a Mk3 in very good condition, I can remove the joints and boots and ship them to you in a USPS flat rate box. Make me an offer if interested.
Look, if corn and kudzu fall in love and have a baby in a lab under the supervision of scientists working in my employ, WHO AM I TO STOP THAT other than the CEO responsible for stopping it???
My Bio
Reply #10June 08, 2010, 08:41:16 pm
« Reply #10 on: June 08, 2010, 08:41:16 pm »
Sorry I missed that last post.
I got a CV shaft from rock auto for the drivers side bolted up. Apparently, MKII cars don't need the spindle changed. I am pretty sure the MKI does, but the difference on the MKII is not really seen much. I had both shafts out and side by side not much diifference at all.
All torqued up and still rolled around fine :D
