Author Topic: bosch injector  (Read 4090 times)
December 04, 2005, 08:49:33 am
bryanbryan89x
  • 110
bosch injector
« on: December 04, 2005, 08:49:33 am »
Hi, my 1981 vw rabbit diesel, with a bosch fuel system on it, leaks diesel out of the injectors (where you screw the two halfs of the injector together) so i took the injectors out and had them rebuilt, put them back in and it is still leaking diesel.  I at first thought it was the run off lines (3.2 mm lines that run from injector to injector) I replaced those, and it wasnt them.  Is this the place where i got them rebuilts fault?  or should i buy bran new injectors (all four are leaking)?
thanks for any help
bryan
1981, Rabbit Car, 1.6, N.A.
Reply #1December 04, 2005, 10:07:28 am
fspGTD
  • 1529
bosch injector
« Reply #1 on: December 04, 2005, 10:07:28 am »
If your injectors are leaking from between the halves, it is due to a sloppy injector rebuild.  Good injector rebuilders will hone the sealing end of the injector holder on a surace plate to make it totally smooth and flat.  The injector halves should also be torqued together to proper specs with a torque wrench.  Hope this helps
Jake Russell
