Author Topic: need source for MK2 disk brake perportioning valve.  (Read 5522 times)
May 07, 2010, 10:46:44 am
« on: May 07, 2010, 10:46:44 am »
if anyone knows where i could come by a new or used perportioning valve for an 85 gti? i need to figure something out soon, im cruising around with ONLY front brakes, no rears.
i would go for a known good used one, or a brand new one if someone could find one. the parts stores around here said they are NLA..
Reply #1May 07, 2010, 11:28:18 am
Re: need source for MK2 disk brake perportioning valve.
« Reply #1 on: May 07, 2010, 11:28:18 am »
The Worldpac guys carry them, although on the 85 they show as the kind that attaches to the master cylinder rather than the under-the-car version:
Honkin big link
Reply #2May 07, 2010, 01:21:40 pm
« Reply #2 on: May 07, 2010, 01:21:40 pm »
well, my car definitely has one under the car.. operated by the rear axle.
Reply #3May 07, 2010, 01:53:10 pm
« Reply #3 on: May 07, 2010, 01:53:10 pm »
http://www.autohausaz.com/search/product.aspx?sid=z4mo5145rja4f445fgnpwx55&makeid=800026@VW&modelid=1282766@JETTA TDI&year=1985&cid=14@Brake %26 Wheel Hub&gid=1888@Brake Proportioning Valve/Pressure Regulator
Big link, but it is autohaus new. This is for  an 85 jetta...I need one as well.
Reply #4May 07, 2010, 04:43:42 pm
AudiVWguy
« Reply #4 on: May 07, 2010, 04:43:42 pm »
Are you running stock brakes on the front? When I did the conversion on the caddy I eventually eliminated the prop-valve altogether. I wet the street down in front of my house, doing a wet braking test, the fronts locked up first. It might be different in the snow. :o Do the test and see what happens.
Cheers,
-JB
Reply #5May 07, 2010, 06:43:08 pm
Runt
  • 83
« Reply #5 on: May 07, 2010, 06:43:08 pm »
I realize that this is sort of a hijack, but shouldn't you test brake bias in the dry?  The way I see it, the more traction you have, the more you are able to unweight the rears, at which point the bias comes into play.  It would follow (assuming that I'm not out in left field so far) that as it got wet or icy the bias would move towards the fronts, I think this is why vw moved to the dynamic proportioning valve.  Actually pretty neat how those work inside.
As best I could tell, the dynamic one I took off when I replaced the drums with disks did not have check valves in it, only the prop mechanism.  I thought all drum setups had check valves, but this did not seem to.  Maybe the self adjusters keep things tight enough that the checks are unneccesary?  Given the number of people who say that they run without them, I'm surprised that you say your rears are not working.
One DD 92 Jetta, One 91 Collision write-off, and One 92 rust free shell, beautiful, stripped, waiting for diesel-ization.
Reply #6May 08, 2010, 04:22:14 am
« Reply #6 on: May 08, 2010, 04:22:14 am »
What I linked I know drum brake cars use. I don't know about the disc brake cars though.
Reply #7May 08, 2010, 08:15:30 am
« Reply #7 on: May 08, 2010, 08:15:30 am »
i live in the pacific north west. it rains all the time. i would rather do a wet test.
Reply #8May 08, 2010, 10:38:37 am
  • 2931
« Reply #8 on: May 08, 2010, 10:38:37 am »
I do it on a gravel road south of town,
my brake adjustment test track.
 Pretty easy to see when they locked up.
