General Information
Troubleshooting
After Market Turbo for 1.6 n/a engine
Topic: After Market Turbo for 1.6 n/a engine (Read 4140 times)
April 28, 2010, 05:43:35 pm
TijuanaTom
Newbie
April 28, 2010, 05:43:35 pm »
I wonder if its possible to install a turbo to my non turbo 1.6 diesel engine?
Would a callaway or garnet work?
Thanks, JM
April 28, 2010, 08:16:51 pm
mystery3
Re: After Market Turbo for 1.6 n/a engine
April 28, 2010, 08:16:51 pm »
Short answer yes. Anything is possible and turboing your na 1.6 falls closer to simple rather than possible. Any kit for an 8v gasser will probably work perhaps with some minor modifications. You will need an egt gauge so as to not melt stuff, the td motors have oil squirters to keep things cooler and are made of slightly different alloys to withstand higher heat. I would suggest reading a large portion of this site and using the search function. There is much knowledge in this site.
April 30, 2010, 01:41:23 pm
April 30, 2010, 01:41:23 pm »
you can boost it fine, although just dont go wild. you will crack a block eventually.. ive already done it a couple times..
May 07, 2010, 04:39:03 pm
Smokey Eddy
May 07, 2010, 04:39:03 pm »
a COUPLE of times?!?!
Ed
THROWN ROD
May 07, 2010, 11:58:32 pm
tthayer
User+
May 07, 2010, 11:58:32 pm »
And where do you keep finding new blocks?
May 08, 2010, 11:27:16 pm
mystery3
May 08, 2010, 11:27:16 pm »
The junkyard probably? Or the classifieds, craigslist etc.
May 09, 2010, 09:09:26 am
May 09, 2010, 09:09:26 am »
Quote from: Smokey Eddy on May 07, 2010, 04:39:03 pm
yes Ed, ive murdered AT LEAST 2 blocks with just boost alone. blew the whole end of #4 cyl off the block on the last one. i had a feeling i knew what was up when there was oil and coolant on my drivers side tire, and running down my fender. thats how hard it exploded. my hood was closed too.
General Information
Troubleshooting
