Author Topic: how bad of a leak is this?  (Read 4725 times)
April 22, 2010, 05:08:34 pm
orengutan
  • 27
« on: April 22, 2010, 05:08:34 pm »
so I was trying to track down an oil leak the other day in my 1.9td and noticed my coolant looked a bit low. I made a note to investigate when I had a bit more time, and the very next day my low coolant light came on.
so this is what I found:
http://i44.tinypic.com/2mmgtv7.jpg (sorry, rotate 90 degrees)
for a better angle, on another site: http://www.brainhotel.org/vanagon/engine_codes.png its the connector for the hose marked A (not my car, clearly).
loose clamp, or tragedy afoot? (this week I've already dealt with my clutch going, fuel leak, potential oil leak, and now coolant - ***ty ***ing week).
ideally, I'd like a quick diagram if anybody has one, of the coolant system, since I haven't actually looked at this on the td yet.
Reply #1April 22, 2010, 05:34:08 pm
orengutan
  • 27
Re: how bad of a leak is this?
« Reply #1 on: April 22, 2010, 05:34:08 pm »
okay, so having done a bit of research, what I'm looking at is the head cylinder coolant flange, and this is probably an o-ring or the flange itself warping (??) that needs to be changed.
Reply #2April 22, 2010, 05:38:21 pm
orengutan
  • 27
« Reply #2 on: April 22, 2010, 05:38:21 pm »
my next question is, can this in any way be related to an oil leak? O_o
Reply #3April 22, 2010, 06:30:37 pm
Turbinepowered
  • 1206
« Reply #3 on: April 22, 2010, 06:30:37 pm »
It's probably your o-ring, yes. And no, that can't really be related to an oil leak.
Reply #4April 22, 2010, 06:41:34 pm
orengutan
  • 27
« Reply #4 on: April 22, 2010, 06:41:34 pm »
is it worth replacing the whole flange since I'm already doing this? they appear to be regarded as "common failure points" online, but it looks like a fairly solid part to me.
Reply #5April 22, 2010, 07:55:40 pm
« Reply #5 on: April 22, 2010, 07:55:40 pm »
Yup... they jus loves to warp... and they aren't much more expensive than the o-ring.  You'll need to partially drain the cooling system.. or move very fast.   ;)
