Author Topic: How to test pump off the car?  (Read 4650 times)
November 28, 2005, 07:07:59 am
myke_w
  • 1099
« on: November 28, 2005, 07:07:59 am »
Is there any way to test the functionality of an IP off the car?
The one in question spins freely and stops on the lands. I would jlike to know before I put it on the car....
Reply #1November 28, 2005, 08:29:29 am
Justin
  • 455
« Reply #1 on: November 28, 2005, 08:29:29 am »
put it in a vise, fill it with diesel or atf, hook up a battery to the main body and the electric fuel shut off to turn it on, hook up your injector lines and injectors, put a quart jar with diesel and put your in and out of the injection pump in the jar, then turn the pump with a drill and push on the throttle and see if you get the injectors to spray, you might have to bleed the injector lines
later
Justin
www.archeryprostaffmi.com
Reply #2November 28, 2005, 10:51:09 am
myke_w
  • 1099
« Reply #2 on: November 28, 2005, 10:51:09 am »
Wow, no kidding? Will this help to diagnose if it leaks too?
Reply #3November 28, 2005, 12:56:48 pm
Justin
  • 455
« Reply #3 on: November 28, 2005, 12:56:48 pm »
its what i have always done before to test them before i put it on the car, so far so good i have only done it to like 2 of them though, and you should be able to detect leaks from it since you will be building pressure in the pump
later
Justin
