Author Topic: fuel line size matter?  (Read 2668 times)
April 16, 2010, 09:27:15 am
dyoungen
  • 128
« on: April 16, 2010, 09:27:15 am »
I have a 1985 Jetta DLX Diesel with a/c. I noticed fuel leaking from the fuel line a couple of days ago and found the line leaking at the fuel line clamp right under the passenger seat. I cut the line and put a brass fitting into the line but am wondering if the smaller size will matter. The fitting is a 1/8" barb fitting and compared to the original line is smaller. All of my experiance has been with an Isuzu 2.2 liter Diesel and a Ford 6.9 liter Diesel and  those have been 3/8" line or 5/16 line. I just don't want to make the IP work harder and die on me as it's running great right now including the a/c. I'm not sure if the broken line was the feed or return line.
Reply #1April 16, 2010, 11:31:11 am
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
Re: fuel line size matter?
« Reply #1 on: April 16, 2010, 11:31:11 am »
The VE pump won't "die" it just might not be able to support the draw you want it to if you crank the fueling up with that added restriction.
it's a mechanical hydraulic... pump it can suck through a pretty long & narrow straw - no homo.
Ed
Reply #2April 16, 2010, 10:16:08 pm
dyoungen
  • 128
« Reply #2 on: April 16, 2010, 10:16:08 pm »
Thanks!! It makes me feel better. I do have a question. How do you fix one of these fuel lines that are so small? Replace the whole thing?
Reply #3April 16, 2010, 11:29:44 pm
Smokey Eddy
  • 3468
« Reply #3 on: April 16, 2010, 11:29:44 pm »
i deleted the "water seperator" which is a strange box thing that is supposed to take the water out of diesel (which isn't an issue anymore with today's pump diesel) and i just made up for the slack with a piece of pipe and two good hose clamps. I just jammed the pipe into either end (they were different ID lines for some reason).
I'd get two double sided barbed fittings with ID's the same as the fuel line and just force them into the line. worse comes to worst you tear part of the fuel line and have to cut off half an inch and go a size smaller on the fittings.
and of course connect said 2 fittings with the necessary length of fuel line rated for diesel of course.
Ed
Reply #4April 17, 2010, 07:34:15 am
GEE-BEE
  • 1604
« Reply #4 on: April 17, 2010, 07:34:15 am »
The flexable is 7mm, I have some if you need it
from hardline to filter, pump return to hardline..
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #5April 19, 2010, 12:14:09 pm
dyoungen
  • 128
« Reply #5 on: April 19, 2010, 12:14:09 pm »
Where is the water seperator or is that the box under the back seat with the cap on the bottom? The fuel filter has the drain at the bottom which I figured was to drain the water.
Reply #6April 19, 2010, 12:25:55 pm
Smokey Eddy
  • 3468
« Reply #6 on: April 19, 2010, 12:25:55 pm »
The water seperator is under the back seat yes. It is unessisary.
the drain on the fuel filter is to flush the filter i think?
i've drained it before and normal looking diesel just comes out of it.
Same with the water seperator.
the main reason for removing it is because it has a sensor in it that till set off the glow plug light in the dash. so when you remove it you want to join those two wires together so you don't get any annoying flickering or flashing of the glow plug light while you're driving.
Ed
