Author Topic: WTB front sway bar / stabilizer bar MK1  (Read 5667 times)
April 12, 2010, 10:28:33 pm
2strokesmoke
« on: April 12, 2010, 10:28:33 pm »
Hi,
I'm looking for a good used front sway bar / stabilizer bar,with all 4 mounting brackets and bushings,to retrofit into my 82 VW pickup / Caddy.
I believe these were stock pieces on the early GTI's up to 84' ?
Bushings are optional,as I would be installing with new bushings anyway..If they are still available ?
Let me know what you have and how much $$
Thanks,Mike
Reply #1April 23, 2010, 10:31:51 pm
2strokesmoke
Re: WTB front sway bar / stabilizer bar MK1
« Reply #1 on: April 23, 2010, 10:31:51 pm »
ttt
Reply #2April 23, 2010, 10:36:21 pm
mystery3
  • 774
« Reply #2 on: April 23, 2010, 10:36:21 pm »
The bushings are available but not too easy to track down, you can find them on ebay. As for the bar I found mine in the junkyard on a later cabby. There are a couple of different sizes, I think 25mm and 28mm?
Reply #3April 24, 2010, 04:21:12 am
ilikevwdiesel
  • 1202
    • Erupt into a BEVRAGE this summer with Glug!
« Reply #3 on: April 24, 2010, 04:21:12 am »
I have a complete setup from an 83 Rabbit GTI. 40 bucks.
Look, if corn and kudzu fall in love and have a baby in a lab under the supervision of scientists working in my employ, WHO AM I TO STOP THAT other than the CEO responsible for stopping it???
My Bio
Reply #4April 24, 2010, 07:24:19 am
GEE-BEE
  • 1604
« Reply #4 on: April 24, 2010, 07:24:19 am »
I have a new front & rear for a caddy 250.00
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #5April 24, 2010, 09:50:16 pm
2strokesmoke
« Reply #5 on: April 24, 2010, 09:50:16 pm »
PM sent to ilikevwdiesel
Thanks for all your input and offers !
much appreciated !
Reply #6April 24, 2010, 10:26:52 pm
mystery3
  • 774
« Reply #6 on: April 24, 2010, 10:26:52 pm »
GB
What rear bar is it? I've been scouting the junkyard for a low cost solution for this as well.
Reply #7April 25, 2010, 07:54:32 am
GEE-BEE
  • 1604
« Reply #7 on: April 25, 2010, 07:54:32 am »
Addico set , front & rear....
GB
« Last Edit: April 28, 2010, 07:54:15 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #8April 25, 2010, 10:59:46 pm
mystery3
  • 774
« Reply #8 on: April 25, 2010, 10:59:46 pm »
ADDICO SET, BRAND NEW
I wish my paypal account had a few more dollars in it! Those bars would be in the mail.
Reply #9April 26, 2010, 08:48:07 pm
Quantum TD
  • 1195
« Reply #9 on: April 26, 2010, 08:48:07 pm »
The Addco bars are still available new for about $220-250. Check out JC Whitney. That's for the Caddy rear sway (different from Rabbit).
Just about every aftermarket company out there makes upgraded kits for MK1 Sedans and convertibles. AFAIK, Addco is the only company that still makes a rear bar for the Caddy.
FYI to the original poster. Let us know how you solve the fuel line issue. The rear mounting cups for the control arms (and sway bar) will hit your fuel feed and return lines. You'll have to reroute them in order to make the sway bar mounting cups fit. On the MK1 GTis and Cabriolets, the fuel were routed in FRONT of the mounting cup. On all MK1 Diesels, the fuel lines are BEHIND the mounting cup/brackets.
Reply #10April 27, 2010, 09:23:50 pm
2strokesmoke
« Reply #10 on: April 27, 2010, 09:23:50 pm »
Quantum TD, Thanks for the "heads up".
I didn't realize the fuel lines would need to be re-routed.
I've never actually seen a MK1 front sway bar setup,installed (only kits for sale)
Every rabbit I ever owned,pitched horribly around turns and off ramps. I think the sway bar and it's necessary mods,will be well worth it in a caddy as well.
I'll post the install,when I get the bar.
Agian,thanks for the info !
Reply #11May 01, 2010, 03:53:47 pm
dennis
  • 311
« Reply #11 on: May 01, 2010, 03:53:47 pm »
MK1 front sway bars are on most Cabriolets, and all Scrioccos. Of course GTIs too.
1980 Caddy TD (Always in progress)
1983 Volvo 245 D24 NA Building D24T
1980 Air-cooled Westy
1956 F100 (What to do???))
Reply #12May 03, 2010, 06:22:53 pm
ilikevwdiesel
  • 1202
« Reply #12 on: May 03, 2010, 06:22:53 pm »
one sway bar and bushings on the way to Mike.
thanks! ;D
My Bio
