Author Topic: AEL timing?  (Read 4685 times)
April 11, 2010, 12:18:05 am
oldskool rich
  • 446
AEL timing?
« on: April 11, 2010, 12:18:05 am »
anyone know what the 5 pot AEL/AAT is timed to
my timing belt fell off  :(
f6squared I.D.S.T
Reply #1April 11, 2010, 04:41:14 am
snakemaster
  • 405
Re: AEL timing?
« Reply #1 on: April 11, 2010, 04:41:14 am »
i done one not to long ago no belt on her eather , got the engine to tdc and marked the pump pully in 5 at the start off lift on the plunger and moved the pump to each of the marks untill it started then did the pump timming to ear . no markes on the pump pully or a key way :( on the 5 pot pump
Reply #2April 11, 2010, 04:33:20 pm
oldskool rich
  • 446
Re: AEL timing?
« Reply #2 on: April 11, 2010, 04:33:20 pm »
there is, its a little dimond on the flyweight marks up to a dot on the pump bracket i think isnt it?
its 0.55 on a transporter will that be the same as audi?
f6squared I.D.S.T
Reply #3April 14, 2010, 09:13:02 am
gigaz2
  • 626
Re: AEL timing?
« Reply #3 on: April 14, 2010, 09:13:02 am »
after it starts just use vagcom to time it properly.
or are you going the Mtdi route?
Reply #4April 16, 2010, 04:21:11 am
emikkels
  • 1
Re: AEL timing?
« Reply #4 on: April 16, 2010, 04:21:11 am »
AEL timing is 0,25mm +-0,02mm
