AAZ head info needed - valve face depth
Topic: AAZ head info needed - valve face depth (Read 3674 times)
March 27, 2010, 01:23:22 pm
March 27, 2010, 01:23:22 pm »
Dr Diesel and myself are trying to build a database of the valve face depth on various AAZ heads. If you have one apart and can measure both the intake and exhaust that would be swell. The MK2 Bentley lists the tolerances but for some reason it was left out of the MK3 Bentley. Also if you know if your head has had the seats cut, head milled etc that would also be good to know. Thanks y'all
March 28, 2010, 06:01:43 pm
subsonic
Re: AAZ head info needed - valve face depth
March 28, 2010, 06:01:43 pm »
I have an older aaz head core and the brand spankin new one on the franky project. You had any measurements off new ones yet?
March 28, 2010, 06:48:43 pm
March 28, 2010, 06:48:43 pm »
Yes absolutely.
March 29, 2010, 03:24:02 pm
Dr. Diesel
Authorized Vendor
March 29, 2010, 03:24:02 pm »
Which is to say, please send us both!
Accuracy is critical.
Thanks!
Just to be completely clear, we're looking for the measurement from the valve faces (both intake and exhaust, all 8, if possible) to the head's gasket surface. Effectively, how deeply recessed the valves are from the head deck.
Last Edit: March 30, 2010, 06:11:41 am by Dr. Diesel
March 30, 2010, 08:06:54 am
clarkrep
March 30, 2010, 08:06:54 am »
I'll get you some dimensions this evening. My head has about 100k original miles and is worn some.
How accurate do you want? Is plus/minus .001 close enough?
Aaron
'79 Rabbit Diesel L 1.5
'83 Rabbit GTI 1.6TD
March 30, 2010, 09:48:49 am
March 30, 2010, 09:48:49 am »
Yesh 0.001 is accurate enough.
Actually we'll take any numbers as long as we know what the accuracy range is.
March 30, 2010, 08:53:20 pm
clarkrep
March 30, 2010, 08:53:20 pm »
Here ya go. 1.9 AAZ '96 model with 100K miles.
Never been had seats cut or valves ground AFIK.
Measured with a depth mic in inches.
E I E I I E I E
.040 .035 .034 .038 .041 .037 .041 .042
Last Edit: March 31, 2010, 05:19:19 am by clarkrep
March 31, 2010, 05:51:17 am
Dr. Diesel
Authorized Vendor
March 31, 2010, 05:51:17 am »
Excellent.
Thank you very much!
Keep 'em coming, folks!
February 22, 2012, 07:11:31 am
February 22, 2012, 07:11:31 am »
Sorry to bring it up from the dead.
I am wondering if this info would apply to 1.6 mechanical head vw. I am thinking of my next build and want to be ready if needed.
Round 2
