Author Topic: Motor Mounts  (Read 5816 times)
March 21, 2010, 06:30:28 am
SolarSteve
  • 264
Motor Mounts
« on: March 21, 2010, 06:30:28 am »
I'm not sure if my passenger side motor mount is bad on my 1991 N/A Jetta.  If the engine is running and I am at a stop, in neutral, I have a lot of vibration/rattling coming from in front of the pass seat.  Its not an IP too advanced rattle, its more like a, motor vibration being transfered to the body type rattle.
I am not sure about this because when the motor is under load it goes away.  Is this indicative of a bad mount?
Thanks
Steve
Steve
91 Jetta 1.6 N/A
Reply #1March 21, 2010, 03:48:00 pm
SolarSteve
  • 264
Re: Motor Mounts
« Reply #1 on: March 21, 2010, 03:48:00 pm »
Maybe I should re-word this.
Can anyone tell me what are the indications of a broke right rear(paasenger side) motor mount?
Thanks
Steve
91 Jetta 1.6 N/A
Reply #2March 21, 2010, 06:03:38 pm
SolarSteve
  • 264
Re: Motor Mounts
« Reply #2 on: March 21, 2010, 06:03:38 pm »
Well, I just ordered a rear mount from GAP.  Hopefully this will fix my problem.  I guess if the problem remains I will replace the front mount.
Steve
91 Jetta 1.6 N/A
Reply #3March 21, 2010, 07:29:32 pm
Dakotakid
  • 1240
Re: Motor Mounts
« Reply #3 on: March 21, 2010, 07:29:32 pm »
I've never seen one of the back mounts go bad in a Mk. II.
Look to see if the little heat shield piece on the exhaust manifold has rusted free or vibrated loose and is klinking around.
Reply #4March 21, 2010, 07:49:21 pm
truckinwagen
  • 1895
Re: Motor Mounts
« Reply #4 on: March 21, 2010, 07:49:21 pm »
I have one of the passenger rear mounts go bad on my 85 GTI, under hard acceleration the two brackets will bang together.
nothing wrong with fresh mounts.
83 Opel Kadett Diesel
Reply #5March 22, 2010, 05:55:28 am
SolarSteve
  • 264
Re: Motor Mounts
« Reply #5 on: March 22, 2010, 05:55:28 am »
I already ordered the rear mount so I guess I will be changing it.
The other day I tried to rock the engine by hand by grabbing the V/C and pushing/pulling and nothing really seemed loose.  I will try to have someone look at the motor today while I begin to engage the clutch.  I can't really figure out what else it might be, but when I am in neutral or stepping on the clutch the noise and vibrations are pretty ugly.
Unfortunately the Bentley has nothing on this.
Steve
91 Jetta 1.6 N/A
Reply #6March 22, 2010, 06:03:00 am
Re: Motor Mounts
« Reply #6 on: March 22, 2010, 06:03:00 am »
you cant really rock the engine with it still supported on the mounts. cause the engine and trans still weighs in at about 300 or so pounds. if you were to put a jack under the oil pan and jack it up just a slight amount, just to get the load off the mounts, then you should be able to rock it on the mounts.
Reply #7March 22, 2010, 05:03:03 pm
Re: Motor Mounts
« Reply #7 on: March 22, 2010, 05:03:03 pm »
and you can run it with it jacked up and see if the vibrating goes away ;)
Reply #8March 22, 2010, 08:14:48 pm
  • 1739
Re: Motor Mounts
« Reply #8 on: March 22, 2010, 08:14:48 pm »
Since you are going to probably change the mount anyways, do this before  or once it's in. Loosen all the vertical mount bolts enough so they're loose- both engine mounts  and the transmission one. Then give  the engine a good rocking: it should align everything so the mounts are doing what they are supposed to. Have a look as you then tighten it all up. None of them should look out of center or forcing.
Reply #9March 31, 2010, 08:38:29 am
Re: Motor Mounts
« Reply #9 on: March 31, 2010, 08:38:29 am »
how hard is it to drive the bushings out of the mounts? im doing new mounts on a few different cars this year.
Reply #10March 31, 2010, 08:14:42 pm
Powjetta
  • 152
    San Diego CA
Re: Motor Mounts
« Reply #10 on: March 31, 2010, 08:14:42 pm »
I replaced that mount and then did the front one next, it seemed to help the most.  Have a friend look at the front mount while you apply power fwd and reverse to see if it moves too much.
'86 jetta 2 dr Turbo diesel K24 - sold
'94 GMC 6.56TD - sold
Reply #11April 01, 2010, 11:34:11 am
Re: Motor Mounts
« Reply #11 on: April 01, 2010, 11:34:11 am »
oh, i KNOW these mounts are SHOT. they need to be replaced bad, just wanted to know how hard it is to drive those bad boys out.
