you didn't by chance get this idea from me did you? not that it matters, but I'm thinking that this will be awesome in my spyder, a little over two tons with a topped out 1.6 with an aaz head and about 35 pounds of boost. The only thing that does concern me, is that I do want to take trips, is there a way to put a tall final gear in so that I can do that? I don't want to say it, but I want to have my cake and eat it too. FF .71 final any good for this?Kevin
Quote from: NintendoKD on March 17, 2010, 10:37:14 pmyou didn't by chance get this idea from me did you? not that it matters, but I'm thinking that this will be awesome in my spyder, a little over two tons with a topped out 1.6 with an aaz head and about 35 pounds of boost. The only thing that does concern me, is that I do want to take trips, is there a way to put a tall final gear in so that I can do that? I don't want to say it, but I want to have my cake and eat it too. FF .71 final any good for this?Kevinthe gears are too wide in the FF. ACN is good for what you want to do. i have one in my car. 3k @70 mph. the first 4 gears are spaced pretty nice for a diesel, then you grab fifth and just cruise.and how on this earth does an MR2 weigh over 4000 pounds? my 89 4runner weighs about 2 tons. there is no way your mr2 spider weighs 4000 lbs...
Since you already have the 4K, you might as well just put it in and try it out. The hot ticket might be to install the .71 5th gear from the FF. You could do this while it is in the car or out. However the 4th to 5th shift into hyper drive may be problematic because of the big drop in RPM. In that case you could use a .75 5th for a difference of approximatley 200 RPM. I am running the stock AVX trans with 4.25 final in my 91 Jetta ECOdiesel and it is way fun to drive around town. The gear ratios are the same as an AGS but with a different final. The AGS is 3.94. The AVX has a .75 5th but could definitely use a .71 5th even though it would only drop the RPMs by about 200. My car is not a great highway cruiser with the AVX as it is right now. I have a junk ACH with a .75 5th that I need to dismantle and may have a line on a 4 speed from a Rabbit that has a .71 5th that I can pirate. Good info on ratios is here:http://www.a2resource.com/eandt/ratios.html
4th gear out of a 4 speed wont work as fifth gear in a 5 speed. as 5th gear is outside the actual trans case. if you want to do something like that, just leave the 3+E alone and install it.
Your looking for a 4.25 final with a .71 5th? thats not too bad, you'll cruise at 2600 rpm in 5th at 60 mph.AND BE PEPPY AS ALL HELL THROUGH TOWN LOL
