Author Topic: piston:connecting rod orientation  (Read 9699 times)
March 04, 2010, 03:56:53 pm
khanh.le
  • 7
« on: March 04, 2010, 03:56:53 pm »
This is a stupid question b/c I double-checked and took pics of items during the disassembly...well I lost those pictures.  What is the correct orientation of the connecting rod to the piston i.e. the forge marks (bumps) on the connecting rod in relation to the piston and its crown from the front of the engine.
Bentley says "forged marks must be toward engine's intermediate shaft with conn. rod and piston installed in engine.", but again I wanted to make sure.
Thanks
Reply #1March 04, 2010, 04:51:37 pm
Re: piston:connecting rod orientation
« Reply #1 on: March 04, 2010, 04:51:37 pm »
I think you got it right. That is the way I put mine in, so I hope you are right.
Reply #2March 05, 2010, 06:54:15 am
rs899
  • 647
« Reply #2 on: March 05, 2010, 06:54:15 am »
I agree- mine looked like that when I re-ringed about 500 miles ago and nothing has blown up yet.
Reply #3March 05, 2010, 07:06:33 am
« Reply #3 on: March 05, 2010, 07:06:33 am »
thats how my engine was re assembled 15k miles ago. looks like you got it right.
Reply #4March 05, 2010, 07:58:36 am
rodpaslow
  • 670
« Reply #4 on: March 05, 2010, 07:58:36 am »
You can check when you install them as the little surface deviation you can see (looks like two circles) should be towards the front of the engine, intermediate/oil filter side of the engine.  Bently shows it that way.
99' 1.9 1Z Tdi, hybrid pump -1.9 housing & rover internals, 2052 wastegate turbo,.25 hflox nozzles, SDI intake, CTN tranny
96' 1.6 TD Golf, Giles pump, VNT 17, Gas changed to Diesel, Air to Water Int.
Reply #5March 05, 2010, 08:49:58 am
rs899
  • 647
« Reply #5 on: March 05, 2010, 08:49:58 am »
Can't quite tell from the picture, but I hope you aren't reusing the stretch bolts on the con rods ( if they are the newer stretch bolts)
Reply #6March 08, 2010, 12:08:34 am
khanh.le
  • 7
« Reply #6 on: March 08, 2010, 12:08:34 am »
Thanks for the help guys.  Those are the old rod bolts, was not planning on replacing them but am now considering otherwise.  Is there a difference between rod bolts for mech vs. hydraulic engines?  Where is a good/cheap source for replacements? (i.e. ARP, if it can fit into the budget)
Reply #7March 08, 2010, 06:11:42 am
rs899
  • 647
« Reply #7 on: March 08, 2010, 06:11:42 am »
According to the Bentley, the factory started using stretch bolts somewhere in the mid-80s.  The earlier 1.6NAs had "normal" reusable (?) bolts.  I re-used the bolts from CR series engines when I re-ringed my later ME engine.  If you are using pistons from the earlier series with their bolts, you should be OK.  Of course, it's always safer to use new bolts, but the prices on these new stretch bolts I think is quite high.
Rick
Reply #8March 08, 2010, 06:15:08 am
« Reply #8 on: March 08, 2010, 06:15:08 am »
Yeah new rod bolts are high...best I could find was 70.00 at the dealers and it was only 100 for ARP, so I got the ARP and they have already paid for themselves as I have taken the pistons out 3 times now as I keep the never ending project going.
Reply #9March 08, 2010, 07:48:12 am
« Reply #9 on: March 08, 2010, 07:48:12 am »
i re torqued my 1.5 bolts with no problems. they didnt seem to stretch, or have any weird torque spec. and its a way early engine. no way theres stretchers in this engine.
Reply #10March 08, 2010, 09:52:21 am
gnavs
  • 340
« Reply #10 on: March 08, 2010, 09:52:21 am »
does anyone have the ARP part number handy?
Reply #11March 08, 2010, 10:31:58 am
rabbitman
  • 2788
« Reply #11 on: March 08, 2010, 10:31:58 am »
Reply #12March 08, 2010, 10:41:14 am
gnavs
  • 340
« Reply #12 on: March 08, 2010, 10:41:14 am »
in the FAQ the con rod ARP bolts are listed for 1.6/1.7, are they the same for AAZ?
Reply #13March 08, 2010, 07:30:25 pm
rodpaslow
  • 670
« Reply #13 on: March 08, 2010, 07:30:25 pm »
After reading this post I was concerned about having to replace the rod bolts.  But, my bently service manual 85 thru 92 GTI, Golf & Jetta does not come out and say the rod bolts need replacing.  When checking clearances they say to torque to 22 ft. lbs. and assembly torque is 22 ft. lbs+90 deg.
I imagine the 90 deg is the stretch.  It also says if to be re-used they should never be interchanged, but nothing about bolt replacement....
Reply #14March 08, 2010, 07:54:23 pm
« Reply #14 on: March 08, 2010, 07:54:23 pm »
The +90 is a pretty good sign that they are stretch bolts. Guilianot had a rod go through the back of his freshly rebuilt AAZ because the mechanic didn't replace the rod bolts.
