Author Topic: piston:connecting rod orientation  (Read 9696 times)
Reply #15March 08, 2010, 07:56:16 pm
rodpaslow
  • 670
Re: piston:connecting rod orientation
« Reply #15 on: March 08, 2010, 07:56:16 pm »
will do - replace or possible disaster...
Reply #16March 18, 2010, 11:15:54 am
khanh.le
  • 7
« Reply #16 on: March 18, 2010, 11:15:54 am »
Back from the dead...
I have a ME engine and I've noticed that there are casting numbers on later-style engines, unlike my previous MK1 engines.  When I removed the piston and rods, I labeled them accordingly.  The order I have labeled does not correspond to the castings.  Below is a breakdown.
My markings.    Vs.     Casting numbers
     1.                                         3
     2.                                         4
     3.                                         1
     4.                                         2
Essentially 1 and 3, 2 and 4 are switched.  I trust my labeling, but I can see some instances where I could've mixed them (however I doubt in such a systematic way).  I have a MK1 bentley, no MK2 so no mention of this.  Sorry to nitpick.
TIA,
Khanh
Reply #17April 01, 2010, 08:33:56 am
TurboJ
  • 661
« Reply #17 on: April 01, 2010, 08:33:56 am »
Make sure you replace the rod bolts - if they have the torque + degrees tightening sequence, they are surely stretch bolts. And if the price is high, I suggest looking around, I typically pay around 20$ for a complete set, and they are FeBi Bilstein made. Also, the 1.9 has different bolts, as do the gas engines (which are again different).
Jetta II 1.6 TD 'Project 200'
