Author Topic: How much boost on stock turbo'd AAZ?  (Read 3616 times)
March 01, 2010, 01:25:59 pm
booneylander
  • 21
« on: March 01, 2010, 01:25:59 pm »
Here's a good one for you guys to solve:
-Stock Turbo'd '96 Golf w/AAZ (not intercooled).
-Basic tweak on the IP (smoke screw).
-Boost controller set to 17psi
-I accelerate onto a highway. I'm paying attention to traffic and getting ready to merge.
-Top of 2nd gear (~4800rpm) I hear a small bang and the car bogs, HARD. I get an eruption of black smoke behind me and I lose track of the cars that were following me onto the ramp.
-Fearing getting rear-ended and being in a not-so-pull-over-friendly spot, I keep going with the car still bogging, it clears it's throat and motors onto the highway.
-I get off at the next exit and assess the situation, I find:
-The line to the wastegate had blown off. So the wastegate probably slammed shut and the turbo boosted it's little heart out until it stalled the compressor, which meant I all of a sudden had no air, causing the black smoke and bog.
-The line blew off the boost gauge from the boost spike, not that it would have told me much as it only reads to 20psi.
-Put everything back together and she still runs like a top (luckily).
So the question is, how much boost do you think I managed before the compressor stalled?
 ;D
Reply #1March 01, 2010, 02:00:13 pm
Henchman
  • 183
Re: How much boost on stock turbo'd AAZ?
« Reply #1 on: March 01, 2010, 02:00:13 pm »
18-20psi
Under way - 1991 Passat Syncro Wagon w/m-tdi
1991 Passat GL Wagon w/AAZ conversion (now using engine/tranny from 1993 Passat
1993 Passat GL 1.9 Diesel (RIP 385k km, engine, tranny, clutch all original)
Reply #2March 01, 2010, 03:58:17 pm
4wheeler
« Reply #2 on: March 01, 2010, 03:58:17 pm »
Depends on what turbo you have...
K03 25 ish
k14 35ish
Reply #3March 01, 2010, 04:25:40 pm
blackdogvan
  • 574
« Reply #3 on: March 01, 2010, 04:25:40 pm »
« Last Edit: March 01, 2010, 08:45:54 pm by blackdogvan »
1991 Vanagon 1.9 mTDI
Reply #4March 01, 2010, 04:56:20 pm
Dirtrag2
  • 298
« Reply #4 on: March 01, 2010, 04:56:20 pm »
 ;D
my boost gauge goes up to 35... that's right about where my k14 stalled when I spiked it with a bypassed wastegate.  same BAD noise then it was like a gasser running on 3 cyl... all ok now tho  ::)
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #5March 02, 2010, 06:25:32 am
booneylander
  • 21
« Reply #5 on: March 02, 2010, 06:25:32 am »
I think it's a K03.
So only ~25, that's not too bad I guess...
