Author Topic: Alternator Swap  (Read 2207 times)
February 21, 2010, 01:57:09 pm
veector
  • 95
Alternator Swap
« on: February 21, 2010, 01:57:09 pm »
Did a bit of searching but couldnt find much.  Im looking at the clutched pulley setup to save my crank since i checked it and put in a new bolt.  I know you can modify the oem aaz alt to fit but im wondering if anything will swap in directly without affecting the pulley offset.  Anything work?
1981 Jetta D
1997 Jetta TD
Reply #1February 21, 2010, 03:27:21 pm
Re: Alternator Swap
« Reply #1 on: February 21, 2010, 03:27:21 pm »
Pulley 028 903 119 AA should spin right on and has the correct offset... at least it worked fine for me.  I added an extra bolt in this thread for safety, but having seen how the TDIs do it I wouldn't bother again:
http://www.vwdiesel.net/forum/index.php?topic=15010.0
Reply #2February 21, 2010, 04:12:19 pm
veector
  • 95
Re: Alternator Swap
« Reply #2 on: February 21, 2010, 04:12:19 pm »
ok cool I guess il just modify my existing one doesnt seem all that hard.  Anyone in Ontario have a link on the spline tool?
« Last Edit: February 21, 2010, 07:59:52 pm by veector »
1981 Jetta D
1997 Jetta TD
Reply #3February 21, 2010, 04:53:15 pm
GEE-BEE
  • 1604
Re: Alternator Swap
« Reply #3 on: February 21, 2010, 04:53:15 pm »
This is for the tensioner type, will it work on the non a/c model as well
Mine is not a fixed type and has a spring underneth the alt ( 90 amp ) keeping the belt tight.
GB
« Last Edit: February 21, 2010, 04:56:50 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
