Author Topic: specifications on cylinder bores.  (Read 1924 times)
February 19, 2010, 11:50:19 am
smoken u
  • 231
« on: February 19, 2010, 11:50:19 am »
ok so i started measuring up the bare block ive had in my basement for about 2 years now, got it from my old work, at the volkwagen shop in alliston, its in good shape, i was told it was new, don know if it is but oh well lol i only payed 50 bucks for it becuase it was just sitting around. anyways i went and checked the cylinder bores, with the bore indicator, and i came up with "3.045 on all 4 cylinders. now that is all fine and dandy, but the bently spec, is "3.122 for standard bore 3.0220 for the 1st oversize, 3.0319 for the 2nd oversize and 3.0516, for the 3rd oversize, so clearly this is not new, what do you guys think should i get the 2nd oversize pistons. or get the block taken to the 3rd oversize??
1990 VW jetta 1.6 td, 2.5" exhaust, no muffler, governor mod 2010 edition, K&N filter. and now 66 hp and 136 ftlbs.
project 1.6 liter in the works  :)
You don't rev a VW diesel, you increase the clatter.
Reply #1February 19, 2010, 03:53:51 pm
smoken u
  • 231
Re: specifications on cylinder bores.
« Reply #1 on: February 19, 2010, 03:53:51 pm »
ha so much for it being a brand new block, oh well, itll be almost brand new by the time im done with it  :)
Reply #2February 19, 2010, 08:46:30 pm
sdwarf36
  • 159
« Reply #2 on: February 19, 2010, 08:46:30 pm »
what are you measuring it with? All the cylinders the same-top/middle /bottom? Something seems fishy-.002 wear? sure--.005 maybe but to be 1st over AND be worn .014? Thats an HUGE amount -I'd check again.
91 Jetta on WVO na / td swap in progress.
 "VW happiness is having 4 working door handles."
Reply #3February 20, 2010, 06:40:07 am
smoken u
  • 231
« Reply #3 on: February 20, 2010, 06:40:07 am »
the cylinders have no taper to them, in fact i can see the crosshatching in the cylinder still so some one may have bpored it, but not exactly done a great job of it, im using a dial bore indicator to measure the bores.
