Author Topic: Another "What The Best" Turbo Question.  (Read 3100 times)
February 19, 2010, 08:41:32 am
ein bora
  • 377
« on: February 19, 2010, 08:41:32 am »
The K14 turbo on my 1.9 IDI may have a seized waste gate - so I maybe looking at repair or replacement. I've read a few things on turbo's on here but I couldn't find anything that suits my question. What would be a good upgrade if any for me, I'm looking for mostly city performance as I am not a real highyway racer. I already have a giles pump, larger exhaust and shortly will be installing an intercooler. Engine's good with less than 60K since rebuild.
Any thoughts appreciated. Thanks.
If you can't take advice - then you can't be helped!
Reply #1February 19, 2010, 11:22:31 am
ein bora
  • 377
Re: Another "What The Best" Turbo Question.
« Reply #1 on: February 19, 2010, 11:22:31 am »
How much boost are you running?
I'm not all that savvy on turbo's or waste-gates let alone safe boost limit's, but I am trying to learn as I go. With the new pump I've hit 20 + easily.
Not sure if this is what you mean??
Reply #2February 19, 2010, 04:13:22 pm
« Reply #2 on: February 19, 2010, 04:13:22 pm »
The K14 probably won't last all that long at 20PSI.  Do you have an EGT gauge?
Reply #3February 19, 2010, 06:32:02 pm
ein bora
  • 377
« Reply #3 on: February 19, 2010, 06:32:02 pm »
I do - and that's why I'm thinking of upgrading.
Reply #4February 19, 2010, 06:40:20 pm
Dirtrag2
  • 298
« Reply #4 on: February 19, 2010, 06:40:20 pm »
IMO a good upgrade for you would be a T3 due to the same exhaust mani flange... you would however have to fab/modify the oil return line for the T3.
i've been running a T3 on my AAZ for well over 60000 km @ 25+ psi with no problems at all.
...Darcy
'97 Jetta 1.9TD ( dirtrag2 )
'88 Fox Wagon ( projekt Dirtrag 3 )
Reply #5February 20, 2010, 05:14:19 am
ein bora
  • 377
« Reply #5 on: February 20, 2010, 05:14:19 am »
Thanks for the response. Lots of choices and prices on the T3. How about the K24 I know it's outdated but any good as a choice?
I did some reading on the GARRETT GT28RS, GT2860RS Turbo's. Maybe that would be a better route.
Any help appreciated. Thanks.
« Last Edit: February 20, 2010, 06:43:04 am by ein bora »
Reply #6February 20, 2010, 07:42:13 am
hippiekiller
  • 73
« Reply #6 on: February 20, 2010, 07:42:13 am »
Not to hijack, but I have the same problem...the only way I can  remove the wastegate on my k14to un-stick it is to take the turbo off, which might or might not happen before I wreck the turbo...I have a k-03 with a manifold that needs a rebuild. Does this turbo compare to the spooling abilities of the k-14?, or should I look for something better...I don't have my pump turned up, but I do have a fairly unrestricted exhaust, and I  can hit 20+ in 2nd....
95 jetta, 2"lift
92 dodge diesel too much to list
Reply #7February 20, 2010, 07:43:34 am
« Reply #7 on: February 20, 2010, 07:43:34 am »
a K03 is stupid, they are all out of boost by like 4000 rpms. and about ready to explode at 20 psi.
Reply #8February 20, 2010, 09:05:33 am
4wheeler
« Reply #8 on: February 20, 2010, 09:05:33 am »
K03 has immediate boost...
great for in town driving.
K14 is a comprimise between city and highway.
K24 -T3`s aer great if you have a giles pump as he would have done teh govenor mod which now can supply the T3 with the revs required for spooling it.
Where are you in ontario? I`ll trade you a T3 for your old K14.
I run a sidekick so my needs are different then yours...
Reply #9February 20, 2010, 10:19:29 am
GEE-BEE
  • 1604
« Reply #9 on: February 20, 2010, 10:19:29 am »
KO3 hybrid !
KO4 Exhaust side with Ko3 boost side
To each is own !
Either way , Speak with Jerry at GPOPSHOP.COM
He has all you need
Iam not looking for power/ boost, just a driver
For power my 08 997TT is just fine
Gee-Bee
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
