Author Topic: It Is Dead.  (Read 4536 times)
February 18, 2010, 11:05:40 am
smutts
  • 720
    ClackClackClackClackClack
It Is Dead.
« on: February 18, 2010, 11:05:40 am »
Funeral March Music.............................
Dumm Dumm Der Dumm Der Der Dumm Der Dumm Der Dum Der etc.
Well, I now don't think it was a tappet, I have explained to the ladyfriend what that funny red light and buzzing noise meant, (you drove it how far?) 20 miles, hmm. Took about a gallon to get anything on the dipstick, yup, abosobloodylutely zero oil in it. Runs on three now, with scary orchestra of destroyed bearing knocks, so tis dead, full of oil a couple of days ago, so just curious as to the most likely post mortem mechanism of death. My bet is on piston break up, or maybe turbo oil seal failure, but there was no runaway. Don't panic as the engine is definately dead, I'm just curious as to how it ate all the oil so as to commit suicide.  ???
« Last Edit: February 18, 2010, 01:30:30 pm by smutts »
Reply #1February 18, 2010, 11:27:26 am
truckinwagen
  • 1895
Re: It Is Dead.
« Reply #1 on: February 18, 2010, 11:27:26 am »
I think you should keep driving it.
the new polos have three cylinders right? and they get fantastic mileage ;D
-Owen
83 Opel Kadett Diesel
Reply #2February 18, 2010, 01:42:23 pm
truckinwagen
  • 1895
Re: It Is Dead.
« Reply #2 on: February 18, 2010, 01:42:23 pm »
because sometimes a runaway does not run out of oil or lock up before it comes apart and sends bits flying very fast in all directions.
Reply #3February 18, 2010, 01:52:28 pm
smutts
  • 720
Re: It Is Dead.
« Reply #3 on: February 18, 2010, 01:52:28 pm »
Sorry Owen, chaos rules, I was trying to paste the following youtube link without it autorunning, this is why the continuity........ isn't...... if you get what I mean.
google    "runaway diesel defender 200 tdi"    to get the idea! see how they run! (can't say I blame them ;D)
« Last Edit: February 18, 2010, 01:57:02 pm by smutts »
Reply #4February 18, 2010, 02:29:35 pm
veedubcanuck
  • 151
Re: It Is Dead.
« Reply #4 on: February 18, 2010, 02:29:35 pm »
OMG!  :o :o
Reply #5February 18, 2010, 04:20:27 pm
catlin_cava
  • 1954
Re: It Is Dead.
« Reply #5 on: February 18, 2010, 04:20:27 pm »
... :o and I thought I was rought on cars lol
Catlin
2010 VW Golf City 2.0L "Hers"
Reply #6February 18, 2010, 05:02:44 pm
Re: It Is Dead.
« Reply #6 on: February 18, 2010, 05:02:44 pm »
that video made me cry.. but listen to how smooth it is holding 7000 rpm's ;) thing is gonna be a champ when he rebuilds it.
Reply #7February 18, 2010, 08:00:34 pm
lovinthedeez
  • 489
Re: It Is Dead.
« Reply #7 on: February 18, 2010, 08:00:34 pm »
good thing they weren't doing laundry that day.   ;D  to the op; sorry :(
Reply #8February 19, 2010, 02:37:09 pm
smutts
  • 720
Re: It Is Dead.
« Reply #8 on: February 19, 2010, 02:37:09 pm »
Hope you wern't too traumatised by the poor Landy eating itself.
Tried the poor thing this evening, it's snowing, it eventualy started, WOW suprised! But big clouds of oil smoke and four big ends knocking out God Save The Queen, It's doomed. Should be fun for a final drive of death to see what gets given birth to out of the block. AA relay card in my pocket. 8)
Just for the curious or gormless, red light and buzzer means STOP AND ADD OIL PLEASE!  ::) ::) ::) :P
« Last Edit: February 19, 2010, 02:39:37 pm by smutts »
Reply #9February 19, 2010, 05:35:18 pm
somolovitch3
  • 290
Re: It Is Dead.
« Reply #9 on: February 19, 2010, 05:35:18 pm »
If it were dead, it would not be "knocking on Heaven's door", or would it?
Just change the lower end bearings, don't even have to take it out of car.
Byte Me, Gently
81 Caddy (Trk)
84 Gti (DumBunny)
Reply #10February 20, 2010, 07:53:10 am
Re: It Is Dead.
« Reply #10 on: February 20, 2010, 07:53:10 am »
i would see how toasted it is before i totally messed up the bottom end. if it still runs, there is still hope for it..
Reply #11February 20, 2010, 01:05:22 pm
Re: It Is Dead.
« Reply #11 on: February 20, 2010, 01:05:22 pm »
Agree. These things take a lot to kill em, and if it's still running.. you didn't give it that much ;)
Reply #12February 21, 2010, 01:55:13 am
LoneWolf
Re: It Is Dead.
« Reply #12 on: February 21, 2010, 01:55:13 am »
Smutts, is yours a 1600 or 1900?
Reply #13February 21, 2010, 02:07:51 am
maxfax
  • 2126
Re: It Is Dead.
« Reply #13 on: February 21, 2010, 02:07:51 am »
I'd bet on the crank and rods being seriously out of whack.. Yeah these things are tough, but they have their limits... The engine I rebuilt for the Bunny had a spun rod bearing from less than a few miles of being run low on oil..  Big end of the rod was somewhat oval shaped, the crank is now bolted to the back of my golf cart for ballast..
Going by your previous posts about the tappity tap tap tap also leads me to think a piston decided it wanted to be somewhere else.. The tapping might have been a crack in the piston around the wrist pin (gudgeon pin I think you call them over there?)  And if that is indeed what happened I'd guess that particular cylinder is none too pretty either...
Then again, stranger things have happened..  Send it over here, I'll weld it up!  ;D
Reply #14February 21, 2010, 09:30:30 am
smutts
  • 720
Re: It Is Dead.
« Reply #14 on: February 21, 2010, 09:30:30 am »
It's the 1600 intercooled SB engine from 1990 ish. It was shagged when I bought it 100,000 miles ago, my first diesel, so I got a bit stitched up. But it has soldiered on fine since, but has always been thirsty for oil, and lumpy compressions, but never got worse till the mystery tapping started up. So I bought a better one, but the girlfriend isn't allowed near that one,
You brave? or need parts?
