Author Topic: Check out my new fuel filter  (Read 5780 times)
February 12, 2010, 09:08:36 am
ein bora
  • 377
« on: February 12, 2010, 09:08:36 am »
Received my new Stanadyne filter system the other day and it looks impressive. Bought this as well as getting my pump re-done by Giles and I must say Giles and Tyler are great guy's to deal with. As you can see in the picture they also threw in a couple of other parts I needed.
Thanks guy's!
If you can't take advice - then you can't be helped!
Reply #1February 12, 2010, 10:49:06 am
Re: Check out my new fuel filter
« Reply #1 on: February 12, 2010, 10:49:06 am »
Glad to hear the parts arrived safely.
Reply #2February 13, 2010, 03:12:25 pm
GIDDY_UP_GO
  • 114
« Reply #2 on: February 13, 2010, 03:12:25 pm »
I am not familiar with this system, can you elaborate on it and why you would change over from the stock system?
Pro's and con's, also, what is the price and how hard to do the install?
I assume that you are putting this on a 1.6 N/A?
In the picture, you have two filters (A big one and a small one) Which one are you using? Then I assume the clear plastic piece to the right is the fuel/water seperator?
86 MK2 Golf Diesel
Reply #3February 14, 2010, 11:50:44 am
Dakotakid
  • 1240
« Reply #3 on: February 14, 2010, 11:50:44 am »
What size microns?
Reply #4February 16, 2010, 06:41:09 am
« Reply #4 on: February 16, 2010, 06:41:09 am »
There is lots of info in this thread.
http://www.vwdiesel.net/forum/index.php?topic=14836.0
When I installed the filter in my Jetta install wasn't quite as easy as it hit the hood
Reply #5February 17, 2010, 09:21:14 pm
« Reply #5 on: February 17, 2010, 09:21:14 pm »
I will for sure be getting one of these! They are "badbutt" ;)
Tyler, for your setup.. is it $38or 39 for the fm10 setup and filter.. then like 19 for the filter from then on? and can it be sourced through you guys for future filters? will you carry these in stock in regularization form ;)
