Author Topic: broken glow plug ?  (Read 3663 times)
January 31, 2010, 12:49:55 pm
mtrans
  • 308
broken glow plug ?
« on: January 31, 2010, 12:49:55 pm »
Hi
When I check my glow plug I see one is broken and missing about 12 mm on top grrrr.It`s IDI and what to do know. I don`t feel takeout head bat I go by this way how many miles.Is there some magic and that damage can done by this .Best
I`ll improve my English
Reply #1January 31, 2010, 07:21:24 pm
ToddA1
  • 434
Re: broken glow plug ?
« Reply #1 on: January 31, 2010, 07:21:24 pm »
I don't really understand the issue...  just replace it.  All of the GPs can be removed without removing the head or IP.
If you're lucky, it's #3 or 4.
-Todd
Reply #2January 31, 2010, 07:27:35 pm
veedubcanuck
  • 151
« Reply #2 on: January 31, 2010, 07:27:35 pm »
I think he means that the end is burned off... Might want to check your injectors, when they leak they will cause the ends to burn off. Was the engine still running?
Reply #3January 31, 2010, 11:20:43 pm
mtrans
  • 308
« Reply #3 on: January 31, 2010, 11:20:43 pm »
Yes it`s broken by top end ( about 12 mm ) I can change  GP and I did ,but top is in  Precombustion Chamber so I gess.Engine is running,Just hard to start because battery,timing, air  and parhaps this 12 mm but than charge battery it`s start. I don`t know when this is begin I am afraid this will fall down in piston -valve, it`s look like this is same very hard material  so I think I am not burn this top by driving so far.Man we mast love this DIESEL engine.
Reply #4January 31, 2010, 11:26:52 pm
« Reply #4 on: January 31, 2010, 11:26:52 pm »
late response :(
I had a Ford  eat a broken tip with no  apparent ill effect, just rattled more than usual for 10 minutes.
I may have just been lucky.
« Last Edit: January 31, 2010, 11:31:21 pm by 745 turbogreasel »
Reply #5February 01, 2010, 04:30:48 pm
dbk
  • 8
« Reply #5 on: February 01, 2010, 04:30:48 pm »
they can burn away slowly It may not have broken off if it runs good drive it Ive' seen stuff rattle around in the cumbustion chamber and just bury itself in the top off the piston without any ill effect bit of a gamble good luck whichever way you go!
Reply #6February 02, 2010, 01:49:30 pm
mtrans
  • 308
« Reply #6 on: February 02, 2010, 01:49:30 pm »
thanks guys for response!
I would like somebody with this problem and have head off  after to say samething but even Lotto is hard by way.All the time inside motor (I believe ) heat and pressure is almost same for top of GP so for 100k it`s survive this conditions and hard  to believe but it will best to melt and evaporate.All my life from a few girls and wife I listen of how importance is this 12 mm.
Reply #7February 02, 2010, 03:04:35 pm
Patrick
  • 1034
« Reply #7 on: February 02, 2010, 03:04:35 pm »
If you think the piece is still in the prechamber, and you want it out, just pull the injector and crank the motor over. Compression will throw the pice out of the engine. Don't forget a new heat shield when you put it back together.
Reply #8February 02, 2010, 04:49:59 pm
  • 3468
    • McScrubbins Body Wash
« Reply #8 on: February 02, 2010, 04:49:59 pm »
I agree. I've seen a heat shield go flying and hit the roof of the garage. It's a dangerous but funny way to remove the old ones once you tap them free.
Reply #9February 03, 2010, 12:31:53 pm
mtrans
  • 308
« Reply #9 on: February 03, 2010, 12:31:53 pm »
man that is exellence.
After your advise I remember even of a vacum cleaner to try.Thanks
Reply #10February 03, 2010, 01:04:06 pm
smutts
  • 720
    ClackClackClackClackClack
« Reply #10 on: February 03, 2010, 01:04:06 pm »
A bicycle spoke works well too.
Reply #11February 03, 2010, 02:16:26 pm
« Reply #11 on: February 03, 2010, 02:16:26 pm »
i take a slightly tapered punch, and stick it in the hole of the heat shield. then i push down a little, then rock it and pull the shield out of the head.
Reply #12February 04, 2010, 12:35:32 pm
mtrans
  • 308
« Reply #12 on: February 04, 2010, 12:35:32 pm »
hello
great but my head is still on motor if I understand you well
