Author Topic: oil change  (Read 2435 times)
January 24, 2010, 07:53:55 am
54321chris
oil change
« on: January 24, 2010, 07:53:55 am »
Is there a way not to have oil run down my sleeve when I loosen the oil filter?   :P  I always make a mess with the filter.  How are you guys handling taking this thing off?
Reply #1January 24, 2010, 07:56:02 am
Re: oil change
« Reply #1 on: January 24, 2010, 07:56:02 am »
Take it off from the top, that's what I do. It still makes a mess, but not all down your arm.
Reply #2January 24, 2010, 09:26:55 am
GEE-BEE
  • 1604
Re: oil change
« Reply #2 on: January 24, 2010, 09:26:55 am »
If i had the room for a remote housing ( oil filter ) I would go that direction..
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3January 24, 2010, 09:32:04 am
Powered by Spearco
  • 1203
Re: oil change
« Reply #3 on: January 24, 2010, 09:32:04 am »
Wait, are you asking about your TDI or the Corrado?
If its the TDI, then how are you getting oil down your sleave. They come out the top before the oil is drained from pan.
If its the Corrado, I stuff rags between the block and the filter to catch or soak up the oil.
'78 Rabbit..Gas Weekend Racer
'13 Golf R:. Tuned
'98 Puch G320
Reply #4January 24, 2010, 10:38:47 am
Re: oil change
« Reply #4 on: January 24, 2010, 10:38:47 am »
i just leave the oil filter socket on the bottom of the filter, the oil flows between the filter and socket then drains out the bottom of the socket, into my drain pan. i dont get oily when i change my fluids.
Reply #5January 24, 2010, 10:54:48 am
54321chris
Re: oil change
« Reply #5 on: January 24, 2010, 10:54:48 am »
Haha, definitely the Corrado.  Rabbit, that sounds like a great idea.  I have the strap kind of wrench now but may have to look into the socket type.  And I'm sure rags would help.  Thanks for the ideas!  Hopefully I'll remember them come next oil change...
Reply #6January 25, 2010, 03:08:20 pm
arb
Re: oil change
« Reply #6 on: January 25, 2010, 03:08:20 pm »
Me too. Also, before I install the new filter, I pre-fill it with oil to save wear and tear on the bearings during startup that first dry time.
