Author Topic: mk2 1.9 td swap almost complete. Questions...  (Read 10324 times)
January 20, 2010, 02:31:33 pm
brandon5
  • 88
« on: January 20, 2010, 02:31:33 pm »
Ok so my swap is nearly complete. Just a few more minor details... plus the entire mk3 dash swap
So here are some pictures.
rats nest wiring
old dash
new dash
dual rad fan cut to fit
t3
trunk storage
headliner
I still dont know what to do with this stuff. If i already have a wastegate on the turbo what do i do with the wiring?
Ill try and post pics as i get closer with my progress.
Any help i can get will be awsome. Seeing as i wanna drive this fricken
thing.
« Last Edit: January 21, 2010, 11:03:31 am by brandon5 »
Reply #1January 20, 2010, 02:56:58 pm
Re: mk2 1.9 td swap almost complete. Questions...
« Reply #1 on: January 20, 2010, 02:56:58 pm »
Congrats, looks pretty good :)
Is there a way you can host pictures right to your post? instead of links? makes viewing a little easier.
Reply #2January 20, 2010, 03:20:00 pm
brandon5
  • 88
« Reply #2 on: January 20, 2010, 03:20:00 pm »
Ya sorry about that :-\ Image shack wasnt to good to me. Ill check it out tomorrow. If i get new pics too. But i need to know about the wastegate wiring first.
Reply #3January 21, 2010, 11:03:58 am
brandon5
  • 88
« Reply #3 on: January 21, 2010, 11:03:58 am »
pictures put up right. I need help with this people!!!!
Reply #4January 21, 2010, 11:37:50 am
« Reply #4 on: January 21, 2010, 11:37:50 am »
a lot of the wiring isn't really necessary. looks like you have a very newer style 1.9 though! where did you get it? i wonder if the 505 00 oil sticker on the valve cover is stock?
im not sure why you took the whole dash off? but while you're in there i highly recommend throwing in a new heater core (and i'm not kidding...) because if it hasn't already been replaced, it will need to be eventually. i also recommend rebuilding the heater box with new foam to help with the cold winters.
it also looks to me like your wastegate is vacuum controlled. that IS a good thing! good by you can control your boost to whatever you wish. there are PWM circuits available on ebay that you can use to control your boost from inside the cab. PWM circuits with variable frequency are like fast switches. the faster they go, the more times the switch is activated meaning the wastegate is opened more. the lower the frequency or even off, the more the wastegate is closed or fully closed. this gives you some really finite boost control. Giles bought one, and his setup is pretty slick  8)
if you're tight on cash and really want this thing going, then just leave those wires alone and get a boost gauge. keep the boost levels to around 15 psi max until you get a feel of the engine, and the amount of smoke coming out the tailpipe. the boost pressure alone won't damage the engine, but too much fuel and boost will.
as for the solenoids on the pump, some can be given 12v all the time to negate their functions (theres one that retards the timing to reduce NOx etc...) it's really that easy. i'm sure others with more knowledge of how to 'trick' these newer style pumps will chime in though. it almost looks as if your pump has that plunger position sensor too...
Reply #5January 21, 2010, 03:48:35 pm
brandon5
  • 88
« Reply #5 on: January 21, 2010, 03:48:35 pm »
I took the whole dash out because im replacing it with a mk3 dash :) ill check the heater core and stuff to. I filled it up with all the fluids it needed and tried to start it but nothing happend :( The only thing i can think of is a relay missing for the computer. Its labeled number 30 on the chart. I also have a few other questions about some tubes coming off the turbo but ill put them up tomorrow.
thanks alot
Reply #6January 21, 2010, 05:25:09 pm
« Reply #6 on: January 21, 2010, 05:25:09 pm »
That wastegate stuff can just be deleted. It's an emissions thing that disables your turbo.
There is no computer for that engine. Just power to the stop solenoid away you go. Glowplugs help of course...
Reply #7January 21, 2010, 06:26:20 pm
Henchman
  • 183
« Reply #7 on: January 21, 2010, 06:26:20 pm »
I have the same sticker on my AAZ in my B3 Passat out of Germany.  Mine does not have the lda and the EGR setup is different.
Do you have a mk3 speedo cluster to go with the dash?
Ian
Under way - 1991 Passat Syncro Wagon w/m-tdi
1991 Passat GL Wagon w/AAZ conversion (now using engine/tranny from 1993 Passat
1993 Passat GL 1.9 Diesel (RIP 385k km, engine, tranny, clutch all original)
Reply #8January 21, 2010, 10:52:58 pm
brandon5
  • 88
« Reply #8 on: January 21, 2010, 10:52:58 pm »
Im kinda of a complete noob but whats a stop solenoid? I just remember seeing in the bently something about an ecm relay. and it doesn't have one in the fuse box. So im guessing i can just leave the waste gate the wiring? or just pull it from the fuse box and get rid of it?
And i have everything for the mk3 dash, cluster, heater box, everything. I have like 3 boxes full.
Reply #9January 22, 2010, 04:57:33 am
« Reply #9 on: January 22, 2010, 04:57:33 am »
The stop solenoid is on the top of the steel part of the pump, just above the injection lines. There is another similar one on the side of the pump. The top one needs power, the other one you can decide if it needs power or not. It will run just fine both ways.
Reply #10January 22, 2010, 01:35:46 pm
brandon5
  • 88
« Reply #10 on: January 22, 2010, 01:35:46 pm »
it seams i have power to everything i need and its a no go. Wont turn over, just clicks. any ideas?
Reply #11January 22, 2010, 01:53:04 pm
« Reply #11 on: January 22, 2010, 01:53:04 pm »
bad ground from the batt.
Reply #12January 22, 2010, 02:01:29 pm
« Reply #12 on: January 22, 2010, 02:01:29 pm »
Check in the FAQ for a voltage drop test. That will tell you exactly where your problem is.
Reply #13January 23, 2010, 09:37:52 am
brandon5
  • 88
« Reply #13 on: January 23, 2010, 09:37:52 am »
Will do. But the grounds should be fine. Im getting power cause my lights and my cluster works. Is there anyway someone can make a quick list of things that i need to get the initial turn over? That would help me out alot.
Thanks alot guys
Edit: will the drop test do anything if my engine wont even crank?
« Last Edit: January 23, 2010, 09:44:25 am by brandon5 »
Reply #14January 23, 2010, 09:37:14 pm
brandon5
  • 88
« Reply #14 on: January 23, 2010, 09:37:14 pm »
Bumbity bump
