foxracer1's Race only Daily Driver build and KILL thread
Pages:
4
Topic: foxracer1's Race only Daily Driver build and KILL thread (Read 16445 times)
Reply #15
January 19, 2010, 09:10:04 pm
foxracer1
Authorized Vendor
Re: foxracer1's Race only Daily Driver build thread
Reply #15 on:
January 19, 2010, 09:10:04 pm »
I think i got a couple crappy phone vids of cold start cause it sounds sweet to me when its idling like ***! ha Sounds good under load when warmed most would want a muffler but the turbo is enough muffler for me.
I'll get some vid when i dyno it! best time to get sound of load yet not be moving.
91 S10 305 TPI T56
86 S10 2WD Prerunner project.
Reply #16
January 20, 2010, 07:31:50 pm
91redjetta
Reply #16 on:
January 20, 2010, 07:31:50 pm »
TURBO MUFFLER!
Reply #17
January 21, 2010, 12:35:37 pm
spencebm
Reply #17 on:
January 21, 2010, 12:35:37 pm »
updates...foxracer1 makes saturns look bad
Ben Spencer
Reply #18
January 21, 2010, 03:00:47 pm
Reply #18 on:
January 21, 2010, 03:00:47 pm »
what are the pump mods?
Reply #19
January 22, 2010, 10:11:21 am
91redjetta
Reply #19 on:
January 22, 2010, 10:11:21 am »
he makes saturns hot from his exhaust temp at 1,600 all day long.. piston tops saying,"please not more!"
i gave him his cold start movie's he's sent me so he needs to post them!
Reply #20
January 22, 2010, 10:33:28 am
91redjetta
Reply #20 on:
January 22, 2010, 10:33:28 am »
the checker board hood is what gives him away in a high speed chase though!!
Reply #21
January 22, 2010, 12:06:24 pm
foxracer1
Authorized Vendor
Reply #21 on:
January 22, 2010, 12:06:24 pm »
spencebm/91redjetta= smart***es!
Trev0rbr - Got 10mm plunger from TDI pump, gov mod, green timing advance spring with minimal shims, timing is around 1.04mm gonna set for max power while on the dyno. oh and a gasser in tank pump feeding it.
I'll see what i can do about posting the vids...
Guess i should post in the smoke tales about the high speed chase.
Last Edit: January 22, 2010, 12:22:52 pm by foxracer1
91 S10 305 TPI T56
Reply #22
January 22, 2010, 12:41:01 pm
foxracer1
Authorized Vendor
Reply #22 on:
January 22, 2010, 12:41:01 pm »
32 degrees real moist out. Been sitting for 2 days with no block heater.
Running after starting second time fromk above vid. Will stay running after first crank if i hold it above idle for about 15-45 secs.
Think this one is the old worn out 1.6 starting on a rather cool fall day. notice still have green grass.
Oh and cell phone vids and pics SUCK!
Last Edit: January 22, 2010, 12:43:55 pm by foxracer1
91 S10 305 TPI T56
Reply #23
January 22, 2010, 12:48:49 pm
foxracer1
Authorized Vendor
Reply #23 on:
January 22, 2010, 12:48:49 pm »
Starting after car sat all day while at work. You can here the ol' mack idling in the background.
91 S10 305 TPI T56
Reply #24
January 22, 2010, 04:34:32 pm
91redjetta
Reply #24 on:
January 22, 2010, 04:34:32 pm »
F-ing sweet!
Reply #25
January 22, 2010, 05:16:41 pm
Reply #25 on:
January 22, 2010, 05:16:41 pm »
i've read over daves 200hp build quite a few times, he had his timing set at 1.25, hopefully that helps, he said after 1.15 it cleared up alot
Reply #26
January 22, 2010, 05:47:48 pm
foxracer1
Authorized Vendor
Reply #26 on:
January 22, 2010, 05:47:48 pm »
Yeah i rememeber reading about that. Its not too bad i like it reminds me of the tractor pullers! Once its warm it runs real good.
But i feel it could use more timing since the peak cylinder pressure is down with the lower compression. Like i said i wanna run it on the dyno and see what make the most power than if its really high maybe back it off a notch so i'm not at the raged edge all the time. It is the daily driver.
Moving to cali this spring so won't have to worry too much about the cold starts out there.
91 S10 305 TPI T56
Reply #27
January 23, 2010, 08:25:05 am
91redjetta
Reply #27 on:
January 23, 2010, 08:25:05 am »
just have to out run the mud slides now!! ha ha ha
Reply #28
January 23, 2010, 08:49:43 am
foxracer1
Authorized Vendor
Reply #28 on:
January 23, 2010, 08:49:43 am »
How to keep your rabbit truck runnin clean!
91 S10 305 TPI T56
Reply #29
January 23, 2010, 08:55:21 am
91redjetta
Reply #29 on:
January 23, 2010, 08:55:21 am »
ha.. someone has to do it.. if either of our old men drove them they'd be plugged solid by now..
Pages:
4
