Author Topic: looking for BIG set of IDI Nozzles to fit 1.6L TD holders  (Read 4671 times)
October 30, 2005, 08:48:24 am
therabbittree
  • 299
« on: October 30, 2005, 08:48:24 am »
I am looking for a set of nozzles for my 1.6L TD engine im going to use with my 12mm pump etc it has di cam plate and moves a bunch of fuel..i know the 1.6 GTD nozzles or the 1.9 L TD nozzles will fit .where can i source a set?..how do they flow compared to each other? and where can i get bigger nozzles then that?..any one do some custom nozzles?..any body have a source for turbo diesel prechambers?.. i decided to do this idi pretty well 1.9L mls headgasket , raceware studs, new seals, etc with my 12mm pump....any ideas tips etc..redrotors? giles etc
thanks
Deo
Reply #1October 31, 2005, 09:07:45 am
fspGTD
  • 1529
« Reply #1 on: October 31, 2005, 09:07:45 am »
Hey Deo - I am developing super high-flowing VW Diesel IDI nozzles. 8)   I have machined some prototypes, and will be flow testing them and will be able to compare them to stock very soon.  After testing is completed, I would like to make them available for others.  If you are interested in ordering one of the first sets for on-car testing, send me an IM.
If you are interested in a set of stock VW nozzles that flow more than the 1.6l units, ask VWMike or Smog about GTD nozzles or 1.9lTD nozzles.
I don't know of a source on prechambers.
Jake Russell
Reply #2October 31, 2005, 09:54:13 am
therabbittree
  • 299
« Reply #2 on: October 31, 2005, 09:54:13 am »
thanks keep me in the loop..red rotor  as contacted me and let me know about teh 1.9L and gtd nozzles also that 6.2 and 6.5 chevy nozzles fit ..so im looking for some of those to try hehehe..keep me updated.
Thanks
Deo
Reply #3October 31, 2005, 03:16:21 pm
935racer
« Reply #3 on: October 31, 2005, 03:16:21 pm »
Hey jake will these flow more than the big chev/gm ones?
Reply #4October 31, 2005, 04:55:36 pm
fspGTD
  • 1529
« Reply #4 on: October 31, 2005, 04:55:36 pm »
It is likely that one of these prototypes I made outflows pretty much anything else you can buy.  The other prototype is much more conservative but still probably has some monster flow...
I don't know much about the Chevy/GM nozzles.  What is their DN0 SD xxx number?  Has anyone tried them in a VW IDI, and if so how well did they work?
If someone wants to send me one for comparison, I'd be happy to let you know how they flow when I soon do my injector flow testing.  :)
Jake Russell
Reply #5October 31, 2005, 04:59:23 pm
935racer
« Reply #5 on: October 31, 2005, 04:59:23 pm »
I have like 8 of them, well they are dvst8rs but they are in my shop! I'll send you one, where too?
Reply #6October 31, 2005, 05:30:23 pm
RedRotors
  • 734
    • http://www.mikrotuning.com
« Reply #6 on: October 31, 2005, 05:30:23 pm »
I tried GM nozzles in my IDI long time ago, the idle was loopey and the smoke was there, but i had a lack of boost, only 10psi.. There's a thread on the old board that explain my testing..
Marc/
2k1 Golf TDI, 11mm pump, HFLOX Warp 5, VNT17, Wavetrac, 4" Lift
91' VW Golf Country
94' Dodge RAM 2500, 4x4, Cummins, 5 spds, 191's, 215hp injectors, SB Clutch
03' Dodge RAM 2500, 4x4, Cummins, 6 spds, MBPR 4 ", custom intake, Smarty Jr
-> www.mikrotuning.com <-
-> www.hflox.com <-
Reply #7November 01, 2005, 04:58:47 am
therabbittree
  • 299
« Reply #7 on: November 01, 2005, 04:58:47 am »
jake ..give me a email or ring I may want to buy a set of these prototypes you've got, for my current ride / project..
let em know
Thanks
Deo
[email protected]
845 270-3467 cell
Reply #8November 01, 2005, 10:44:23 am
935racer
« Reply #8 on: November 01, 2005, 10:44:23 am »
Jake I'll send you one for some measurements. pm me
